Target Platform for 3.4 [message #548473] |
Wed, 21 July 2010 23:19  |
I build my plugins using Buckminster using target definition for Eclipse 3.5. Now I need to do the same build for 3.4. In order to created target definition is it enough to change values of my locations to point to location of ganymede repositories, or 3.4 target definition needs to be created in Eclipse 3.4?
thank you,
Mike
Re: Target Platform for 3.4 [message #549073 is a reply to message #549064] |
Fri, 23 July 2010 21:41  |
Do you mean pde version definition? My TD is
Quote: |
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.5"?>
<target name="iIT Eclipse 3.4 Target">
<locations>
<location includeAllPlatforms="true" includeMode="slicer" type="InstallableUnit">
<unit id="org.eclipse.help.feature.group" version="1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK"/ >
<unit id="org.eclipse.platform.feature.group" version="3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL "/>
<unit id="org.eclipse.rcp.feature.group" version="3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63 "/>
<repository location="http://download.eclipse.org/releases/ganymede"/>
</location>
<unit id="org.eclipse.tptp.platform.batik.feature.group" version="4.4.0.v200812160100-7F8G-ED-z0UWSVlyYUjcN"/>
<unit id="org.eclipse.tptp.platform.batik.pdf.feature.group" version="4.4.0.v200812160100-15-7w311917142611"/>
</location>
<unit id="org.eclipse.draw2d.feature.group" version="3.4.2.v20090218-1145-3317w311_122502441"/>
<unit id="org.eclipse.gef.feature.group" version="3.4.2.v20090218-1145-67728084A56B4I233613552"/>
</location>
<unit id="org.eclipse.gmf.feature.group" version="1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ"/ >
<unit id="org.eclipse.gmf.sdk.feature.group" version="2.1.3.v20090122-1525-7A7879AIkpv6FZKxKlVYDv7PguLk"/ >
</location>
<unit id="org.eclipse.jdt.feature.group" version="3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI"/ >
</location>
<unit id="org.eclipse.emf.query.feature.group" version="1.2.0.v200805130238-11-7w311916241349"/>
<unit id="org.eclipse.emf.ecore.feature.group" version="2.4.2.v200902171115"/>
<unit id="org.eclipse.emf.feature.group" version="2.4.2.v200902171115"/>
<unit id="org.eclipse.emf.codegen.feature.group" version="2.4.0.v200902171115"/>
<unit id="org.eclipse.emf.common.feature.group" version="2.4.0.v200902171115"/>
<unit id="org.eclipse.emf.databinding.feature.group" version="1.0.0.v200902171115"/>
<unit id="org.eclipse.emf.codegen.ecore.feature.group" version="2.4.2.v200902171115"/>
<unit id="org.eclipse.emf.ecore.edit.feature.group" version="2.4.1.v200902171115"/>
<unit id="org.eclipse.emf.mapping.ecore.feature.group" version="2.4.0.v200902171115"/>
<unit id="org.eclipse.emf.edit.feature.group" version="2.4.2.v200902171115"/>
<unit id="org.eclipse.emf.mapping.feature.group" version="2.4.0.v200902171115"/>
<repository location="http://download.eclipse.org/modeling/emf/updates/releases/"/>
</location>
<unit id="org.eclipse.ocl.feature.group" version="1.2.3.v200810101725-3439oA55T5F8H8PAB"/>
</location>
<unit id="org.eclipse.emf.transaction.feature.group" version="1.4.0.v20100428-2315-377-8s734C3E7D15D6B"/>
<unit id="org.eclipse.emf.transaction.sdk.feature.group" version="1.4.0.v20100428-2315-777N-9AZP-D1aQtjUklrYl0eU20D"/ >
<unit id="org.eclipse.emf.workspace.feature.group" version="1.4.0.v20100428-2315-36-8s734C367E3CBC7"/>
</location>
<unit id="org.eclipse.datatools.enablement.feature.feature.group" version="1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj"/ >
<unit id="org.eclipse.datatools.sdk.feature.feature.group" version="1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx"/ >
<unit id="org.eclipse.datatools.sqldevtools.feature.feature.group " version="1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z"/ >
</location>
<unit id="org.eclipse.equinox.executable.feature.group" version="3.3.101.R34x_v20081125-7H-ELfE8hXnkE15Wh9Tnyu"/>
<repository location="http://download.eclipse.org/eclipse/updates/3.4"/>
</location>
<unit id="org.eclipse.platform.sdk" version="3.4.2.M20090211-1700"/>
<unit id="org.eclipse.sdk.ide" version="3.4.2.M20090211-1700"/>
</location>
<unit id="org.eclipse.emf.validation.feature.group" version="1.4.0.v20100428-2315-479-9oB56N5BBR6LCA6"/>
</location>
<unit id="org.eclipse.wst.common_ui.feature.feature.group" version="3.0.4.v200811200248-7C78ELhE8VrRVqtHp4iT8PuSwZ5W"/ >
<unit id="org.eclipse.wst.feature.group" version="3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai"/ >
</location>
</locations>
</target>
Everything points to ganymede repositories, except pde version element which should stay 3.5 as I understand.
I am building all of this in Hudson, against Buckminster 3.6 with TP being in a separate job, artifact of which is used by my build job.
Also, here is my BOM: http://pastebin.com/svg9WQLm
thanks,
Alex
FUDForum. Page generated in 1.09282 seconds
