Home » Eclipse Projects » Eclipse Platform » How to add submenu using extension "org.eclipse.ui.menus"?
How to add submenu using extension "org.eclipse.ui.menus"? [message #547593] Mon, 19 July 2010 02:30 Go to next message
Hi, all:
I want to add a submenu of "Run as" in the "ProjectExplorer".
The followings can add item to the root of popupmenu:
<extension
point="org.eclipse.ui.menus">
<menuContribution locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=additions ">
<dynamic
class="kaitone.wisp.kul.debug.ui.DynamicRunMenu"
id="kaitone.wisp.kul.debug.ui.DynamicRunMenu1">
</dynamic>
</menuContribution>
</extension>
If I write it like :locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=run "
or:
locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=org.eclipse.debug.ui.contextualLaunch.run.submenu "
it does not work...
so how I write the locationURI?
Thanks and Best Regards!
Re: How to add submenu using extension "org.eclipse.ui.menus"? [message #547738 is a reply to message #547593] Mon, 19 July 2010 10:08 Go to previous messageGo to next message
RunAs comes from popupMenus. org.eclipse.ui.menus can't see popupMenus,
but popupMenus contributions can see org.eclipse.ui.menus contributions.
Maybe if you use org.eclipse.ui.menus to define the Run As menu in the
same way it is defined by the objectContributions ....
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to add submenu using extension "org.eclipse.ui.menus"? [message #548224 is a reply to message #547738] Wed, 21 July 2010 03:40 Go to previous message
Paul Webster wrote on Mon, 19 July 2010 10:08
I know where the problem is, maybe I should change another way to do that. I define all the possible menus as "launchShortcut", and for every "launchShortcut" I define a "PropertyTest" to enable or disable the menu item. Luckily there are not so many menu items in my situation.
Thank you very much~
Previous Topic:Where do all those "trace" check boxes come from when debugging a plugin?
Next Topic:Strange content type and encoding detection
Current Time: Sun Aug 31 08:34:22 EDT 2025
Powered by FUDForum. Page generated in 0.03465 seconds
