Home » Eclipse Projects » Orbit » GWT-User not installable with p2
GWT-User not installable with p2 [message #547572] Sun, 18 July 2010 18:34 Go to next message
I have tried to install gwt-user from orbit p2 repository
( http://download.eclipse.org/tools/orbit/downloads/drops/R201 00519200754/repository)
but can't because of "Eclipse-PlatformFilter: (osgi.os=browser)" defined
in MANIFEST.MF of com.google.gwt.user bundle released 2.0.3.v20100419-0751 .
I know that this library is only used at development to generate
javascript but it would be useful to have it installable in standard
target platform to call gwtc compiler for example.
Best Regards.
Re: GWT-User not installable with p2 [message #548117 is a reply to message #547572] Tue, 20 July 2010 13:16 Go to previous messageGo to next message
Esteban DUGUEPEROUX wrote:
> Best Regards.
I appears this invalid filter was removed from cvs version, but the
"fixed" version not released for the R-build. Plus some other process
problems.
But, if it helps, I have just promoted an I-build that has a "2.0.4"
version, which does not have that filter.
http://download.eclipse.org/tools/orbit/downloads/drops/I201 00709085604/
I've also opened following bug, which you can follow or comment on. If
you need 2.0.3 (or, 2.0.4) fixed in an R-build, please say so in the bug
(with the reasons) and we can (probably) fix in Helios SR1.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320422
Re: GWT-User not installable with p2 [message #548204 is a reply to message #547572] Wed, 21 July 2010 01:51 Go to previous message
Am 19.07.2010 00:34, schrieb Esteban DUGUEPEROUX:
You need to check "Include all environments" when installing into your
target platform. However, you still need the gwt-dev.jar with the
compiler which is not in Orbit. I use the GWT Tooling plug-in for
compilations.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: GWT-User not installable with p2 [message #565951 is a reply to message #547572] Tue, 20 July 2010 13:16 Go to previous message
> Best Regards.
problems.
Re: GWT-User not installable with p2 [message #566000 is a reply to message #547572] Wed, 21 July 2010 01:51 Go to previous message
compilations.
-Gunnar
Gunnar Wagenknecht
Previous Topic:SLF4j Version 1.6.0
Next Topic:Version of iText
Current Time: Thu Jul 24 21:50:27 EDT 2025
Powered by FUDForum. Page generated in 0.54655 seconds
