Home » Eclipse Projects » EclipseLink » new jpa project user library requires javax.persistence.entity
new jpa project user library requires javax.persistence.entity [message #548137] Tue, 20 July 2010 14:27 Go to next message
In attempting to create a new jpa project in Helios I am getting the following message in the wizard: "The class 'javax.persistence.Entity' is required to be in the selected libraries". However in the user library I have created I have included javax.persistence_2.0.1.v201006031150.jar, eclipselink.jar, and eclipselink-jpa-modelgen_2.1.0.v20100614-r7608.jar in the defined library. The javax.persistence_2.0.1.v201006031150.jar has the class javax.persistence.Entity so I am baffled by this message.
Re: new jpa project user library requires javax.persistence.entity [message #548145 is a reply to message #548137] Tue, 20 July 2010 15:16 Go to previous message
Have you specified that library as the library to use during project creation? That is, did you create the library during project creation, and did you then *select* that library as the one to use for that project?
FYI, this is more of a Dali topic (JPA/EclipseLink UI tools for Eclipse) rather than an EclipseLink one, per se. The Dali forum can be found here: http://www.eclipse.org/forums/index.php?t=thread&frm_id= 113
Previous Topic:Getting Session Using JpaHelper.getEntityManager
Next Topic:help with moving to JPA
Current Time: Thu Jul 24 20:23:20 EDT 2025
Powered by FUDForum. Page generated in 0.03654 seconds
