Eclipse Plug-in Developer Contract [message #548075] |
Tue, 20 July 2010 11:20  |
The big key is eclipse plug-in development skills.
2+ year contract
NEED SENIOR LEVEL EXPERTS WITH DEEP UNDERSTANDING AND EXPERIENCE - Walk on Water Types!
Team is building IDE for X10. X10 is a type-safe, modern, parallel, distributed object-oriented language intended to be very easily accessible to Java(TM) programmers. It is targeted to future low-end and high-end systems with nodes that are built out of multi-core SMP chips with non-uniform memory hierarchies, and interconnected in scalable cluster configurations.
* eclipse plug-in development - this is the critical requirement - development of plug-ins, not just using them
* building an IDE for a programming language (some aspect of it most likely)
* familiar with parser/generator technologies (abstract syntax trees)
* understand data type information represented by compiler front end (i.e. type of expression is an INT)
* compiler represents types internally - good grounding in compiler technology & frameworks
* experience with static program analysis: type inference; pointer analysis...
real experience and understanding of SWT & JFACE frameworks
need real software engineering experience using bugzilla/ JiRA, how to use eclipse in a team environment, CVS or subversion, how to plan for testing...
people who were major contributors to Java, Scala, C, C++ may be ideal
Re: Eclipse Plug-in Developer Contract [message #584316 is a reply to message #550091] |
Wed, 11 August 2010 19:27  |
Hello - I am not sure if I replied to you already. If not, I apologize for the delay. We are still looking to fill this position, but the person needs to work on-site in Westchester, NY.
Dru Welburn
dru at ivmost dot com
FUDForum. Page generated in 0.04250 seconds
