Home » Language IDEs » PHP Development Tools (PDT) » debug / edit existing web applications on the local server(what is the proper way?)
icon5.gif  debug / edit existing web applications on the local server [message #547992] Tue, 20 July 2010 07:03 Go to next message
Hey Eclipsers!
I'm an experienced developer and very new to Eclipse PDT.
Question What is the proper way to (setup) debug and edit an existing web application on a local server?
I have several local sites running on a virtual windows machine using different domain names, which also is a development environment.
To debug & edit an existing web application, I currently use (file / new / php project / create project at existing location) and selec the web root folder like 'd:\webroot\mysite\html'.
This results in :
1 - Eclipse files and a special folder created in the web root, which is not good. I'd prefer project files kept on a different location and not modify the existing website's structure.
2 - (debug configurations / php web page / url / auto generate) to fail making the right url string. It always adds the project name like:
http://mysite.com/myprojectname/index.php
So I have to uncheck 'auto generate' and delete the project name part. It's not hard, but it kinda points to a problem with the configuration as it shows we couldn't describe the IDE the local files' locations on the site, so it's not aware.
I tried mapping ' / ' to the root folder on file system on the server configuration, but this made no difference.
Am I following a wrong path?
Thank you!
Onur
[Updated on: Tue, 20 July 2010 07:07] by Moderator
Re: debug / edit existing web applications on the local server [message #548192 is a reply to message #547992] Tue, 20 July 2010 23:06 Go to previous messageGo to next message
I'm always using Linked Folder.
(New>Folder>Advanced>Linked Folder)
2.
Unfortunately,
Bug 236971 - Annoying behavior for auto-generating the URL
Re: debug / edit existing web applications on the local server [message #548240 is a reply to message #547992] Wed, 21 July 2010 04:41 Go to previous message
Thanks Toshihiro, this helped much!
Previous Topic:Unable to open file: ...\org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions\jvmargs
Next Topic:Autocomplete for PHP variables and methods
Current Time: Fri Jul 25 18:09:40 EDT 2025
Powered by FUDForum. Page generated in 0.07220 seconds
