Home » Modeling » EMF » Emf.Edit: Deletion of a linkage instead of the linked element itself
Emf.Edit: Deletion of a linkage instead of the linked element itself [message #547755] Mon, 19 July 2010 10:24 Go to next message
if class A is contained by B and additionally referred to by C, this is
reflected in the standard tree-editor by the capability of
drag'n'droping A-objects from their containment position (below
B-objects) to another position (below C-objects) creating the additional
linkage. If I delete an A-object from its position below C, I would
suggest the linkage to be removed only, instead the element is deleted
from the whole model i.e. particularly from its containment!?
Debugging brought to light that when selecting an element in the
tree-editor, method 'DeleteAction.updateSelection' calls
'DeleteCommand.create(domain, selection)'. Triggering the deletion
(pressing del-key) executes this command, removing each element (purely)
listed in 'selection' from its containment. Afterwards, the "correct"
RemoveCommand of the appropriate C-itemprovider is executed, of course
without any effect.
Is this intended behavior and is there a convenient way to change the
behavior to my suggested one?
Thanks in advance,
Stefan
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #547756 is a reply to message #547755] Mon, 19 July 2010 10:30 Go to previous messageGo to next message
Me again,
right after writing this, I found that:
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 0250.html
I will check that first.
Thnx
Am 19.07.2010 16:24, schrieb Stefan Jurack:
> without any effect.
> Thanks in advance,
> Stefan
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #547855 is a reply to message #547756] Mon, 19 July 2010 16:26 Go to previous messageGo to next message
after investigating in the thread (and the referred one) below, further
references and code, I got stuck again.
I changed method "isWrappingNeeded" of my non-model itemprovider to
return true, and so far, the wrapper is created correctly. But when
createCommand of my itemprovider is called, in fact the one of class
ItemProviderAdapter, method unwrapCommandValues discards the feature
setting within the DelegatingWrapperItemProvider, which is important for
deletion.
So, what did I miss? Do I have to override the createCommand method and
set the feature manually? But otherwise, for multiple-selections this
may not fit.
Stefan
Am 19.07.2010 16:30, schrieb Stefan Jurack:
> Me again,
> Thnx
>> Hi,
>> without any effect.
>> Thanks in advance,
>> Stefan
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548031 is a reply to message #547855] Tue, 20 July 2010 09:06 Go to previous messageGo to next message
--------------080708010503020005050001
Stefan,
This logic in DeleteCommand.execute should delete all references to the
object only if it becomes a dangling reference:
for (Map.Entry<EObject, Collection<EStructuralFeature.Setting>>
entry : usages.entrySet())
EObject eObject = entry.getKey();
*if (eObject.eResource() == null)*
So I'm not sure what problem you're seeing.
Ed
Stefan Jurack wrote:
> deletion.
> may not fit.
> Regards,
> Stefan
>> Me again,
>> Thnx
>>> Hi,
>>> without any effect.
>>> Thanks in advance,
>>> Stefan
<html>
<head>
http-equiv="Content-Type">
</head>
Stefan,<br>
<br>
object only if it becomes a dangling reference:<br>
<br>
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548035 is a reply to message #548031] Tue, 20 July 2010 09:42 Go to previous messageGo to next message
Hi Ed,
I missed to tell, that I set method 'removeAllReferencesOnDelete()' in
my xxActionBarContributor to return false (as recommended by you in the
discussion
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 0058.html).
When I did both steps, setting 'removeAllReferencesOnDelete' to return
'false' and 'isWrappingNeeded' to return 'true', the wrappers for my
linked entities are created correctly. Trying to deletion them in the
tree-based editor, however, leads to the deletion of the contained
element anyway instead of the wrapper. Imo, this is due to the fact,
that in ItemProviderAdapter... :
public Command createCommand(Object object, EditingDomain domain,
Class<? extends Command> commandClass, CommandParameter commandParameter)
CommandParameter oldCommandParameter = commandParameter;
commandParameter = unwrapCommandValues(commandParameter, commandClass);
.... method 'unwrapCommandValues' discards any feature information
contained in the wrapper. Thus, it's not clear anymore which feature to
use for deletion... :
else if (commandClass == RemoveCommand.class)
if (commandParameter.getEStructuralFeature() != null)
result = createRemoveCommand(domain,
commandParameter.getEOwner(), commandParameter.getEStructuralFeature(),
commandParameter.getCollection());
else
result = factorRemoveCommand(domain, commandParameter);
.... leading to a call to 'factorRemoveCommand'. Here, any feature is
choosen for removal if the wrapped element is contained in.
I hope this made it clear?!
Stefan
Am 20.07.2010 15:06, schrieb Ed Merks:
> Stefan,
> Regards,
> Ed
>> Hi,
>> deletion.
>> may not fit.
>> Regards,
>> Stefan
>>> Me again,
>>> Thnx
>>>> Hi,
>>>> without any effect.
>>>> Thanks in advance,
>>>> Stefan
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548070 is a reply to message #548035] Tue, 20 July 2010 10:58 Go to previous messageGo to next message
--------------010800080704090600050000
Stefan,
Try not setting removeAllReferencesOnDelete to false. In general, you
really do need to make sure that all references to a deleted object are
removed, otherwise saving will throw dangling reference exception. Once
you do that, pay close attention to what's happening in
DeleteCommand.execute. It should clean up all references to a deleted
object, but only if that object is no longer contained by a resource.
So for the case you describe, the object should only be removed from its
parent. More comments below.
> Hi Ed,
> discussion
Doesn't it keep the feature?
if (newCollection != null || newValue != oldValue)
commandParameter = new CommandParameter(
commandParameter.owner,
*commandParameter.feature,*
newValue,
newCollection,
commandParameter.index);
> else
All children features are considered. Does the same parent both
reference and contain this "child"?
> Regards,
> Stefan
>> Stefan,
>> Regards,
>> Ed
>>> Hi,
>>> deletion.
>>> may not fit.
>>> Regards,
>>> Stefan
>>>> Me again,
>>>> Thnx
>>>>> Hi,
>>>>> without any effect.
>>>>> Thanks in advance,
>>>>> Stefan
<html>
<head>
</head>
Stefan,<br>
<br>
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548084 is a reply to message #548070] Tue, 20 July 2010 11:30 Go to previous messageGo to next message
Hi Ed,
See comments below.
Am 20.07.2010 16:58, schrieb Ed Merks:
> Stefan,
> parent.
Ok.
>> Hi Ed,
>> discussion
> newValue,
> newCollection,
The problem here is, that commandParameter.feature is alway null. In
contrast, the wrapper object contains the required feature, but it is
never used in any way. Consider the following in DeleteAction... :
public Command createCommand(Collection<?> selection)
return removeAllReferences ? *DeleteCommand.create(domain,
selection)* : RemoveCommand.create(domain, selection);
.... which leads to... :
public static Command create(EditingDomain domain, final Collection<?>
collection)
return domain.createCommand(DeleteCommand.class, new
*CommandParameter(null, null, collection)*);
.... Here, the feature in CommandParameter is explicitly set to null,
while collection contains the wrapper class with its feature information
embedded.
Regards, Stefan
>> else
>> Regards,
>> Stefan
>>> Stefan,
>>> Regards,
>>> Ed
>>>> Hi,
>>>> deletion.
>>>> may not fit.
>>>> Regards,
>>>> Stefan
>>>>> Me again,
>>>>> Thnx
>>>>>> Hi,
>>>>>> without any effect.
>>>>>> Thanks in advance,
>>>>>> Stefan
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548091 is a reply to message #548084] Tue, 20 July 2010 11:51 Go to previous messageGo to next message
--------------080302080201060607040908
Stefan,
Comments below.
> Hi Ed,
> See comments below.
>> Stefan,
>> parent.
> Ok.
>>> Hi Ed,
>>> discussion
>> newValue,
>> newCollection,
That's a different issue from what you said about it being discarded...
> In
> collection)
> embedded.
There is no command parameter yet at this point. There's only a
selection for the things that need to be deleted.
So where does this leave things? You're claiming that all references to
the object are being removed? I've directed you to look at what's
happening in DeleteCommand. I would expect that only a single
RemoveCommand is being created and I would expect that to remove the
object from its non-containment reference. What's actually happening?
> Regards, Stefan
>>> else
>>> Regards,
>>> Stefan
>>>> Stefan,
>>>> Regards,
>>>> Ed
>>>>> Hi,
>>>>> deletion.
>>>>> may not fit.
>>>>> Regards,
>>>>> Stefan
>>>>>> Me again,
>>>>>> Thnx
>>>>>>> Hi,
>>>>>>> without any effect.
>>>>>>> Thanks in advance,
>>>>>>> Stefan
<html>
<head>
</head>
Stefan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:i24ff2$5dm$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
See comments below.
</pre>
<blockquote type="cite">
<pre wrap="">Stefan,
parent.
</pre>
</blockquote>
<pre wrap=""><!---->
Ok.
</pre>
<pre wrap="">Stefan Jurack wrote:
</pre>
<pre wrap="">Hi Ed,
discussion
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 0058.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 0058.html</a>).
Class&lt;? extends Command&gt; commandClass, CommandParameter commandParameter)
</pre>
</blockquote>
<pre wrap="">Doesn't it keep the feature?
newValue,
newCollection,
</pre>
</blockquote>
The problem here is, that commandParameter.feature is alway null. </pre>
</blockquote>
That's a different issue from what you said about it being discarded...<br>
<pre wrap="">In
public Command createCommand(Collection&lt;?&gt; selection)
public static Command create(EditingDomain domain, final Collection&lt;?&gt;
collection)
embedded.
</pre>
</blockquote>
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548149 is a reply to message #548091] Tue, 20 July 2010 15:14 Go to previous messageGo to next message
Ed,
hope you don't mind, I've cleaned this post a bit up.
Am 20.07.2010 17:51, schrieb Ed Merks:
Hmm, may be the following fits better: The feature contained in the
wrapper is not taken into account.
>> In
>> collection)
>> embedded.
I marked the newly created CommandParameter with its feature set to
null. If you mean that this is not the command parameter used in the
resulting RemoveCommand, you're right. I only showed this to indicate
that feature is unset from the beginning.
You're right again, only one RemoveCommand is created. This is
something, that has been misinterpreted by me due to a refresh problem.
Nevertheless, the problem occurs anyway in a slightly different shape!
Consider the following:
Class A is contained by B, while C has two (or more) ordinary references
ca1 and ca2 targeting class A. In the tree-editor I distinguish between
ca1 and ca2 by introducing two non-model items. If I delete an object :A
in ca1, which is referred to by ca1 *and* ca2, this leads to confusions
by the algorithm due to method ItemProviderAdapter.factorRemoveCommand
which looks for any(!) feature of :C to contain :A. This is exactly what
happens in my case. The wrong feature is chosen and thus deleted.
Instead of looking for any feature, the feature given within the wrapper
could have been taken into account directly.
Stefan
Re: Emf.Edit: Deletion of a linkage instead of the linked element itself [message #548164 is a reply to message #548149] Tue, 20 July 2010 17:30 Go to previous message
--------------090500010903040601050702
Stefan,
So as I suspected, the problem is with factor remove command not being
able to disambiguate... You'll need to specialize your item provider's
createCommand to deal better with this kind of unusual case, taking into
account the extra information provided by the IWrapperItemProvider
around the child.
> Ed,
>>> In
>>> collection)
>>> embedded.
> Regards,
> Stefan
<html>
<head>
</head>
Stefan,<br>
<br>
into account the extra information provided by the IWrapperItemProvider
around the child.<br>
<br>
<br>
<blockquote cite="mid:i24sj2$kkn$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
</pre>
<pre wrap="">The problem here is, that commandParameter.feature is alway null.
</pre>
</blockquote>
<pre wrap="">That's a different issue from what you said about it being discarded...
</pre>
</blockquote>
</pre>
<pre wrap="">In
collection)
embedded.
</pre>
</blockquote>
<pre wrap="">There is no command parameter yet at this point. There's only a
</pre>
</blockquote>
</pre>
<pre wrap="">So where does this leave things? You're claiming that all references to
</pre>
</blockquote>
Stefan
</pre>
</blockquote>
</body>
</html>
--------------090500010903040601050702--
Previous Topic:Question about notification
Next Topic:XSD to ECORE transformation
Current Time: Sat Jul 19 04:43:08 EDT 2025
Powered by FUDForum. Page generated in 0.05269 seconds
