Home » Archived » BIRT » Aggregating Percentage
Aggregating Percentage [message #547815] Mon, 19 July 2010 12:03 Go to next message
Originally posted by: remkus.wideopenwest.com
I have a report with a column that contains SLA targets for applications
as a percentage.
The report will be aggregating the list of applications into groups.
My requirement is to express the SLA target for the group of
applications as the array of application SLA targets multiplied
together, basically assuming independent probability .... i.e. SLA1 *
SLA2 .... * SLAn.
I'm using BIRT 2.2.2 (yeah, I'm tethered to this version). If BIRT
handles this easily with it's aggregates, I guess I'm just overlooking
it, so I'll apologize in advance.
Do I need to write a custom aggregate to do this? Is there a good
example out there someone can point me to?
Would it be easier to do in my query? (I'm using DB2 as a backend)
Re: Aggregating Percentage [message #548727 is a reply to message #547815] Thu, 22 July 2010 14:13 Go to previous message
Dave,
Not sure I follow what you are trying to do, it sounds like you might be
able to do it through expressions, but my guess is a custom aggregation will
be much easier to use and test.
Scott
> applications as a percentage.
> SLA2 .... * SLAn.
> Thanks
Previous Topic:Actuate 8 Report Errors
Next Topic:Dynamic Sql query in birt
Current Time: Sun Jul 27 11:24:03 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
