Home » Eclipse Projects » Rich Client Platform (RCP) » RCP client for EJB, cannot lookup.
RCP client for EJB, cannot lookup. [message #547536] Sun, 18 July 2010 11:08 Go to next message
Hi there,
I am trying to build a RCP client for an ejb application. Thus, I need to access remote ejb from the rcp client.
I use the following code to do the lookup:
Properties prop=new Properties();
prop.putContext.INITIAL_CONTEXT_FACTORY, "org.apache.openejb.client.RemoteInitialContextFactory");
prop.put("java.naming.provider.url", "ejbd://127.0.0.1:4201");
Context context = new InitialContext(prop);
However, I always get the exception at "InitialContext", the exception is:
Caused by: java.lang.ClassNotFoundException: org.apache.openejb.client.RemoteInitialContextFactory
I have double checked and confirm openejb-client-3.1.2.jar is in Java Build Path and RemoteInitialContextFactory is included in this jar file. The server is Geronimo.
Is there any special way to specify the classpath in RCP application? I have run out of the ideas, please help
Jin
[Updated on: Sun, 18 July 2010 11:08] by Moderator
Re: RCP client for EJB, cannot lookup. [message #547759 is a reply to message #547536] Mon, 19 July 2010 10:30 Go to previous messageGo to next message
Jin,
please note, that this is just a work-around, but it may help in your
case. You could try setting the context class loader to the class loader
of the current thread, i.e.
ClassLoader old = Thread.currentThread().getContextClassLoader();
try {
Thread.currentThread().setContextClassLoader(this.getClass() .getClassLoader);
//new InitialContext...
} finally {
Thread.currentThread().setContextClassLoader(old);
You may then experience further problems when loading/deserializing
instances that are returned from EJB methods. This may happen, if you
have a "generic" Geronimo bundle G and a custom bundle C with your
project-specific classes. As C depends on G, G cannot see C's classes by
default. So you have to specify a BuddyPolicy in G (dependent or
registered). See here for details on the BuddyPolicy
http://www.eclipsezone.com/articles/eclipse-vms/
HTH,
Martin Klinke
http://www.martinklinke.com
Am 18.07.2010 17:08, schrieb Hu Jin:
> Hi there,
> Cheers,
> Jin
Re: RCP client for EJB, cannot lookup. [message #547761 is a reply to message #547759] Mon, 19 July 2010 10:34 Go to previous message
Thinking about it, another more trivial cause for the CNFE may be that
org.apache.openejb.client.RemoteInitialContextFactory has a further
dependency that is not contained in your class-path...
Martin
Am 19.07.2010 16:30, schrieb Martin Klinke:
> Jin,
> try {
> } finally {
> HTH,
> Martin Klinke
>> Hi there,
>> is:
>> Cheers,
>> Jin
Previous Topic:How to call Java RCP based application from Java Swing
Next Topic:How to create Section with toolbar?
Current Time: Fri Jul 25 22:08:39 EDT 2025
Powered by FUDForum. Page generated in 0.04623 seconds
