Home » Modeling » UML2 » EMF bidirectional validation failing
EMF bidirectional validation failing [message #546499] Tue, 13 July 2010 02:51 Go to next message
Dear all, in Helios, literally all my UML models no longer validate,
including trivial new ones. For example, in the Helios Modeling Tools
release, I create a new UML model with the following structure:
+ Model
+ Statemachine
+ Region
+ Transition
+Trigger
Selecting "Validate" in the UML editor will then yield:
"The opposite features 'owner' of '<Trigger> s' and 'ownedElement' of
'<Transition> k' do not refer to each other"
Likewise, in the OCL console, on the transition, querying for 'trigger'
will return the trigger, but both 'ownedMember' and 'ownedElement'
return an empty result set (which is why the validation seems to be
failing).
I'm observing this on two different Helios installations (MacOS MDT
20100617-1415, Solaris x86 3.6RC4).
Thanks in advance for any clues as to what I'm doing wrong!
Volker, F'Up set
United Nations University -
Re: EMF bidirectional validation failing [message #547710 is a reply to message #546499] Mon, 19 July 2010 07:33 Go to previous messageGo to next message
In article <i1kd1d$69d$1@build.eclipse.org>,
Ed Merks <Ed.Merks@gmail.com> wrote:
> Yes, best to ask on the UML newsgroup. I haven't a clue. I wonder if
> the complaints about source and target not being set might be the cause
> of these other problems.
(x-posting/f-up to .uml2)
Hi Ed, I think this might be unlikely. So far I have two instances of
this validation problem:
namespace <-> ownedMember
owner <-> ownedElement
One of those other examples is that if I have
+ Component c
+ Property p
+ InterfaceRealization r
the property is in c.ownedMembers, and the interface realization isn't.
I am wondering if this means that the UML metamodel is not consistent
with your validation rule (from [280397]): it says that ownedMember is
the opposite of namespace, but even from looking at the source (Galileo
and Helios) it is clear that the implementation of e.g. Component never
ensured this. I double-checked with the OCL interpreter in Galileo, it
has the same result (ownedMember doesn't contain the interface
realization), so the only difference seems to be the bidirectional
validation that you added a while ago (I'm not aware of the UML
metamodel changing in the meantime as well).
For clarification, let me give this problem another spin: from looking
e.g. at ComponentImpl, it is obvious that the InterfaceRealization will
only be included in ownedElements, but not in ownedMembers. However, the
Javadoc (presumably generated from the metamodel) says that the opposite
of namespace is ownedMember, which clearly isn't the case for
InterfaceRealization. I am wondering if your validation rule is finally
exposing a bug in the UML metamodel, where either this opposite
feature-relationship was incorrectly specified, or that the generated
code does not correctly reflect that e.g. interface realizations should
be included in ownedMembers.
I guess I'll raise a bug in MDT if nobody else has any idea (and once
I'm past my surprise that nobody else is observing this---it means that
most people are happy with UML class diagrams and don't actually venture
to component diagrams or state machines ;)
Volker
> Volker Stolz wrote:
> > In article <i1hofp$rkn$1@build.eclipse.org>,
> > Ed, thanks for your input. I'm using the Example EMF Model Creation
> > Wizard to create the UML model (here; as reported I get the same problem
> > with programmatically generated UML files).
> > In this case, I only stay within the editor, and there is no (separate,
> > on-disk) Ecore model (except the UML models in-memory representation).
> > There's also nothing in the Error Log, and I just checked with a fresh
> > Classic Helios and only installed the UML2Extender.
> > This is the trivial model.uml (never mind the line breaks). :
> > <?xml version="1.0" encoding="UTF-8"?>
> > <uml:Model xmi:version="2.1"
> > xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
> > xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML"
> > xmi:id="_89dnMI6MEd-MxvZKuoG_jg" viewpoint="">
> > <packagedElement xmi:type="uml:StateMachine"
> > xmi:id="_-hY4EI6MEd-MxvZKuoG_jg">
> > <region xmi:id="__yf6oI6MEd-MxvZKuoG_jg">
> > <transition xmi:id="_ArWOMI6NEd-MxvZKuoG_jg">
> > <trigger xmi:id="_Ba40wI6NEd-MxvZKuoG_jg"/>
> > </transition>
> > </region>
> > </packagedElement>
> > </uml:Model>
> > Should this better go to one of the UML groups?
> > Volker
Re: EMF bidirectional validation failing [message #547721 is a reply to message #547710] Mon, 19 July 2010 09:17 Go to previous messageGo to next message
--------------090308060206020802090103
Volker,
Comments below.
Those are definitely properly paired bidirectional opposites in
UML21.ecore. They are also derived. I believe they are derived from
containment references so they're sort of like a derived containment.
> + Component c
> + Property p
Now you're talking an instances though. I don't see how Ecore
constraints on UML itself end up apply for an instance. UML's own
constraints should apply instead.
> ensured this.
What makes that clear?
Someone in UML land will need to comment. I just don't see how Ecore's
constraints end up apply to UML2 instances. Where in a UML is there an
instance of EReference? Or to ask it another way, what in UML derives
from EReference or reuses EReference?
> Volker
>>> </transition>
>>> </region>
>>> </packagedElement>
>>> </uml:Model>
>>> Volker
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Volker,<br>
<br>
Comments below.<br>
<br>
Volker Stolz wrote:
<blockquote cite="mid:vs-3DDC6F.13330319072010@news.eclipse.org"
type="cite">
<pre wrap="">In article <a class="moz-txt-link-rfc2396E" href="mailto:i1kd1d$69d$1@build.eclipse.org">&lt;i1kd1d$69d$1@build.eclipse.org&gt;</a>,
Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Yes, best to ask on the UML newsgroup. I haven't a clue. I wonder if
</pre>
</blockquote>
<pre wrap=""><!---->
namespace &lt;-&gt; ownedMember
owner &lt;-&gt; ownedElement
</pre>
</blockquote>
UML21.ecore.&nbsp; They are also derived.&nbsp; I believe they are derived from
containment references so they're sort of like a derived containment.<br>
type="cite">
<pre wrap="">
+ Component c
+ Property p
</pre>
</blockquote>
Now you're talking an instances though.&nbsp; I don't see how Ecore
constraints on UML itself end up apply for an instance.&nbsp; UML's own
constraints should apply instead.<br>
type="cite">
<pre wrap="">
ensured this. </pre>
</blockquote>
What makes that clear?<br>
type="cite">
<pre wrap="">I double-checked with the OCL interpreter in Galileo, it
</pre>
</blockquote>
Someone in UML land will need to comment.&nbsp; I just don't see how Ecore's
constraints end up apply to UML2 instances.&nbsp; Where in a UML is there an
from EReference or reuses EReference?<br>
type="cite">
<pre wrap="">
Volker
</pre>
<pre wrap="">Volker Stolz wrote:
</pre>
<pre wrap="">In article <a class="moz-txt-link-rfc2396E" href="mailto:i1hofp$rkn$1@build.eclipse.org">&lt;i1hofp$rkn$1@build.eclipse.org&gt;</a>,
</pre>
</blockquote>
<pre wrap="">Ed, thanks for your input. I'm using the Example EMF Model Creation
&lt;?xml version="1.0" encoding="UTF-8"?&gt;
&lt;uml:Model xmi:version="2.1"
xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://schema.omg.org/spec/XMI/2.1">"http://schema.omg.org/spec/XMI/2.1"</a>
xmlns:uml=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/uml2/3.0.0/UML">"http://www.eclipse.org/uml2/3.0.0/UML"</a>
xmi:id="_89dnMI6MEd-MxvZKuoG_jg" viewpoint=""&gt;
&lt;packagedElement xmi:type="uml:StateMachine"
xmi:id="_-hY4EI6MEd-MxvZKuoG_jg"&gt;
&lt;region xmi:id="__yf6oI6MEd-MxvZKuoG_jg"&gt;
&lt;transition xmi:id="_ArWOMI6NEd-MxvZKuoG_jg"&gt;
&lt;trigger xmi:id="_Ba40wI6NEd-MxvZKuoG_jg"/&gt;
&lt;/transition&gt;
&lt;/region&gt;
&lt;/packagedElement&gt;
&lt;/uml:Model&gt;
Volker
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------090308060206020802090103--
Re: EMF bidirectional validation failing [message #547760 is a reply to message #547721] Mon, 19 July 2010 10:50 Go to previous messageGo to next message
In article <i21ja2$jbo$1@build.eclipse.org>,
> > + Component c
> > + Property p
> > ensured this.
Ed, I'm a bit confused by your remark about instances and constraints
above.
For the example above, you can find, what I understood to be the
calculation of those derived sets, in
org.eclipse.uml2.uml.internal.impl.ComponentImpl:
protected static final int[] OWNED_MEMBER_ESUBSETS = new int[]{
UMLPackage.COMPONENT__OWNED_RULE,
UMLPackage.COMPONENT__OWNED_USE_CASE,
UMLPackage.COMPONENT__OWNED_ATTRIBUTE,
UMLPackage.COMPONENT__OWNED_CONNECTOR,
UMLPackage.COMPONENT__OWNED_BEHAVIOR,
UMLPackage.COMPONENT__OWNED_TRIGGER,
UMLPackage.COMPONENT__NESTED_CLASSIFIER,
UMLPackage.COMPONENT__OWNED_OPERATION,
UMLPackage.COMPONENT__OWNED_RECEPTION,
UMLPackage.COMPONENT__PACKAGED_ELEMENT};
protected static final int[] OWNED_ELEMENT_ESUBSETS = new int[]{
UMLPackage.COMPONENT__OWNED_COMMENT,
UMLPackage.COMPONENT__NAME_EXPRESSION,
UMLPackage.COMPONENT__ELEMENT_IMPORT,
UMLPackage.COMPONENT__PACKAGE_IMPORT,
UMLPackage.COMPONENT__OWNED_MEMBER,
UMLPackage.COMPONENT__TEMPLATE_BINDING,
UMLPackage.COMPONENT__OWNED_TEMPLATE_SIGNATURE,
UMLPackage.COMPONENT__GENERALIZATION,
UMLPackage.COMPONENT__SUBSTITUTION,
UMLPackage.COMPONENT__COLLABORATION_USE,
*** UMLPackage.COMPONENT__INTERFACE_REALIZATION,
UMLPackage.COMPONENT__REALIZATION};
which indicates to me that interface realizations are not ownedMembers
(since they are explicitly listed in ownedElements, but not
ownedMembers, see ***) . But then I wonder how this matches with
ownedMember being supposedly the opposite of namespace!
I am by no means certain where this behaviour might come from (except
that the UML behaviour is unchanged from Galileo to Helios). Of course
there's a chance that the generator that produced the above code should
have, well, generated something else.
I hope you can observe the same behaviour as I do by clicking together a
trivial model using New->UML Model and running Validate from within the
UML Editor.
EObjectValidator.validate_EveryBidirectionalReferenceIsPaire d is called
explicitly e.g. in UMLValidator.validateComponent.
Volker
Re: EMF bidirectional validation failing [message #547779 is a reply to message #547760] Mon, 19 July 2010 11:12 Go to previous messageGo to next message
--------------020807010204060803010306
Volker,
I see. I'm confusing the constraints! Doh!! :-P
_UI_UnpairedBidirectionalReference_diagnostic is the one you're
referring too. In that case, I expect you're right. There's likely
something about UML's derivation of these features that is indeed not
implemented correctly and it's only by checking this constraint that we
find the instances aren't properly conforming to the definition of the
UML model. Hopefully some UML expert will comment on this.
>>> + Component c
>>> + Property p
>>> ensured this.
> above.
> UML Editor.
> Volker
<html>
<head>
</head>
Volker,<br>
<br>
I see.&nbsp; I'm confusing the constraints!&nbsp; Doh!! :-P<br>
<br>
referring too.&nbsp; In that case, I expect you're right.&nbsp; There's likely
UML model.&nbsp;&nbsp; Hopefully some UML expert will comment on this.<br>
<br>
<br>
Volker Stolz wrote:
<blockquote cite="mid:vs-950039.16503319072010@news.eclipse.org"
type="cite">
<pre wrap="">In article <a class="moz-txt-link-rfc2396E" href="mailto:i21ja2$jbo$1@build.eclipse.org">&lt;i21ja2$jbo$1@build.eclipse.org&gt;</a>,
</pre>
<pre wrap="">(x-posting/f-up to .uml2)
</pre>
</blockquote>
<pre wrap="">Those are definitely properly paired bidirectional opposites in
</pre>
<pre wrap="">One of those other examples is that if I have
+ Component c
+ Property p
</pre>
</blockquote>
<pre wrap="">Now you're talking an instances though. I don't see how Ecore
</pre>
<pre wrap="">I am wondering if this means that the UML metamodel is not consistent
ensured this.
</pre>
</blockquote>
<pre wrap="">What makes that clear?
</pre>
</blockquote>
above.
</pre>
<pre wrap="">Someone in UML land will need to comment. I just don't see how Ecore's
</pre>
</blockquote>
trivial model using New-&gt;UML Model and running Validate from within the
UML Editor.
Volker
</pre>
</blockquote>
</body>
</html>
--------------020807010204060803010306--
Re: EMF bidirectional validation failing [message #547812 is a reply to message #547779] Mon, 19 July 2010 12:21 Go to previous messageGo to next message
Hmm, this is a bit of a problem. In UML2, we assume (and have for years)
the implicit container of an element is its owner, and the implicit
container of a named element is also its namespace (if it's a kind of
Namespace). In order to satisfy this new constraint, we'd either need to
stop making this assumption and add a bunch of new subsets constraints
to the metamodel to make it explicit, or else (perhaps more
realistically) bypass the constraint for UML models. In any case, please
open a bug and hopefully someone will look into it.
Kenn
Ed Merks wrote:
> Volker,
>>>> + Component c
>>>> + Property p
>>>> ensured this.
>> above.
>> UML Editor.
>> Volker
Re: EMF bidirectional validation failing [message #548102 is a reply to message #547812] Tue, 20 July 2010 12:17 Go to previous messageGo to next message
Originally posted by: ralf.ellner.cs.fau.de
I tried to reproduce the problem and ran into the same validation error
using a UML model like this:
+ Component c
+ Property p
According to the UML specification the association property
'InterfaceRealization::implementingClassifier' is a subset of
'Element::owner' and 'BehavioredClassifier::interfaceRealization' is a
subset of 'Element::ownedElement'. This is ok because 'Element::owner'
and 'Element::ownedElement' are opposites of each other.
Thus, it is correct that r is not contained in 'Namespace::ownedMember'
of c. However, using the OCL console one gets c as a result when
querying r for 'NamedElement::namespace'. This is obviously wrong and
leads to the validation error. The problem can be found at
NamedElementImpl#basicGetNamespace() which returns the
eInternalContainer (c) of the InterfaceRealization instead of null.
I think the same problem exists at least for 'Component::realization'
and 'ComponentRealization::abstraction'. I will open a bug for this.
Best regards, Ralf
> Kenn
> Ed Merks wrote:
>> Volker,
>> we find the instances aren't properly conforming to the definition of
>> the UML model. Hopefully some UML expert will comment on this.
>>>>> of this validation problem:
>>>> from containment references so they're sort of like a derived
>>>> containment.
>>>>> + Component c
>>>>> + Property p
>>>>> isn't.
>>>>> consistent with your validation rule (from [280397]): it says that
>>>>> ownedMember is the opposite of namespace, but even from looking at
>>>>> the source (Galileo and Helios) it is clear that the implementation
>>>>> of e.g. Component never ensured this.
>>> above.
>>> ownedMembers (since they are explicitly listed in ownedElements, but
>>> not ownedMembers, see ***) . But then I wonder how this matches with
>>>> Ecore's constraints end up apply to UML2 instances. Where in a UML
>>>> is there an instance of EReference? Or to ask it another way, what
>>>> in UML derives from EReference or reuses EReference?
>>> course there's a chance that the generator that produced the above
>>> code should have, well, generated something else.
>>> together a trivial model using New->UML Model and running Validate
>>> from within the UML Editor.
>>> called explicitly e.g. in UMLValidator.validateComponent.
>>> Volker
Re: EMF bidirectional validation failing [message #548221 is a reply to message #548102] Wed, 21 July 2010 03:27 Go to previous message
Kenn already opened a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320318
Best regards, Ralf
Re: EMF bidirectional validation failing [message #628540 is a reply to message #546499] Mon, 19 July 2010 07:33 Go to previous message
+ Component c
+ Property p
Volker
> > </transition>
> > </region>
> > </packagedElement>
> > </uml:Model>
> > Volker
Re: EMF bidirectional validation failing [message #628542 is a reply to message #547710] Mon, 19 July 2010 09:17 Go to previous message
Volker,
Comments below.
> + Component c
> + Property p
> ensured this.
> Volker
>>> </transition>
>>> </region>
>>> </packagedElement>
>>> </uml:Model>
>>> Volker
<html>
<head>
</head>
Volker,<br>
<br>
Comments below.<br>
<br>
type="cite">
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
type="cite">
<pre wrap="">
+ Component c
+ Property p
</pre>
</blockquote>
type="cite">
<pre wrap="">
</blockquote>
type="cite">
</pre>
</blockquote>
type="cite">
<pre wrap="">
Volker
</pre>
</pre>
</pre>
</blockquote>
&lt;/transition&gt;
&lt;/region&gt;
&lt;/uml:Model&gt;
Volker
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: EMF bidirectional validation failing [message #628543 is a reply to message #547721] Mon, 19 July 2010 10:50 Go to previous message
> > + Component c
> > + Property p
> > ensured this.
above.
UML Editor.
Volker
Re: EMF bidirectional validation failing [message #628544 is a reply to message #547760] Mon, 19 July 2010 11:12 Go to previous message
Volker,
>>> + Component c
>>> + Property p
>>> ensured this.
> above.
> UML Editor.
> Volker
<html>
<head>
</head>
Volker,<br>
<br>
<br>
<br>
<br>
type="cite">
</pre>
</pre>
</blockquote>
</pre>
+ Component c
+ Property p
</pre>
</blockquote>
</pre>
ensured this.
</pre>
</blockquote>
</pre>
</blockquote>
above.
</pre>
</pre>
</blockquote>
UML Editor.
Volker
</pre>
</blockquote>
</body>
</html>
Re: EMF bidirectional validation failing [message #628547 is a reply to message #547779] Mon, 19 July 2010 12:21 Go to previous message
Kenn
Ed Merks wrote:
> Volker,
>>>> + Component c
>>>> + Property p
>>>> ensured this.
>> above.
>> UML Editor.
>> Volker
Re: EMF bidirectional validation failing [message #628551 is a reply to message #547812] Tue, 20 July 2010 12:17 Go to previous message
+ Component c
+ Property p
Best regards, Ralf
> Kenn
> Ed Merks wrote:
>> Volker,
>>>> containment.
>>>>> + Component c
>>>>> + Property p
>>>>> isn't.
>>> above.
>>> Volker
Re: EMF bidirectional validation failing [message #628553 is a reply to message #548102] Wed, 21 July 2010 03:27 Go to previous message
Best regards, Ralf
Previous Topic:Dynamic UML
Next Topic:UML 2.0.0 metamodel to UML 2.1.0 metamodel
Current Time: Wed Jul 23 05:37:24 EDT 2025
Powered by FUDForum. Page generated in 0.06281 seconds
