Home » Archived » M2M (model-to-model transformation) » [ATL] Can I apply helpers just on classes used as main class?
[ATL] Can I apply helpers just on classes used as main class? [message #547686] Mon, 19 July 2010 07:10 Go to next message
Hello
I created a helper which has his context related to class ControlFlow.
 helper context EPK!ControlFlow def: isConditionExpression()
Now I wanted to assign this helper to the rule:
-- Rule 9c / 11b
rule Event {
from
	e : EPK!Event (not e.isConditionExpression())
to
Is this not working (context of helper: ControlFlow / from in rule EPK!Event)? How can I then check this?
thanks for your help. Cheers Roger
Re: [ATL] Can I apply helpers just on classes used as main class? [message #547692 is a reply to message #547686] Mon, 19 July 2010 07:23 Go to previous messageGo to next message
Le 19/07/2010 13:10, Roger80 a écrit :
> Hello
> -- Rule 9c / 11b
> rule Event {
> from
> to ..
ATL and EMF respect inheritance principles so if you want to apply your
rule to multiple types which inherit from a main class, you have to put
the main type as context of this rule !!!
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] Can I apply helpers just on classes used as main class? [message #547706 is a reply to message #547686] Mon, 19 July 2010 08:12 Go to previous messageGo to next message
Ok, but then my helper is not working anymore...i need this helper for both rules, once for the Event rule and once for the Control flow rule...do I have to make then two rules?
Re: [ATL] Can I apply helpers just on classes used as main class? [message #547708 is a reply to message #547686] Mon, 19 July 2010 08:15 Go to previous messageGo to next message
Use an OclAny context if there is no common EClass in the inheritance trees of the two classes.
icon14.gif  Re: [ATL] Can I apply helpers just on classes used as main class? [message #547768 is a reply to message #547686] Mon, 19 July 2010 11:00 Go to previous message
Thanks, through your answer I was able to solve it.
Previous Topic:java code
Next Topic:[QVTo] Return from mapping
Current Time: Wed Jul 30 22:16:36 EDT 2025
Powered by FUDForum. Page generated in 0.04452 seconds
