Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Re: Integrating C++ GUI toolkit into RCP application?
Re: Integrating C++ GUI toolkit into RCP application? [message #547532] Sun, 18 July 2010 07:14
Redirecting to SWT-Newsgroups because this is a swt-specific question.
Tom
Am 18.07.10 12:59, schrieb Jarrick Chagma:
> "Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
> news:i1ujg2$a77$1@build.eclipse.org...
>> Normally all you need is the native handle (which is available through
>> platform specific SWT-API) to the parent object which you pass to your
>> C++ library.
> OK, that sounds promising.
>> The most typical problem is that GUI-Toolkits themselves maintain an
>> event loop and mixing 2 of them causes problems as you might imagine so
>> it highly depends how your toolkit is doing event processing.
> Yes, I can see that this would be an issue. The GUI toolkit does have
> its own event loop but as we are developing the toolkit and the RCP
> application that will use it concurrently, we are in a position where
> such concerns can be addressed. What would need to be done in relation
> to the event loop so that it would live well with Eclipse? Are there
> any guidelines for such development?
>> Which platform do you want to use this?
> Hopefully we can develop an Eclipse RCP application that integrates our
> C++ GUI toolkit and runs on all platforms (Windows, Linux and Mac).
Previous Topic:INSTALLING SWT ON ECLIPSE UNDER WINDOWS
Next Topic:SashForm events when dragging the sash?
Current Time: Sun Aug 31 00:49:47 EDT 2025
Powered by FUDForum. Page generated in 0.03541 seconds
