Home » Language IDEs » ServerTools (WTP) » using instanceof in javascript
using instanceof in javascript [message #545369] Wed, 07 July 2010 10:27 Go to next message
I started using eclipse to develop with javascript (actually it's JSFL, but it's close enough). I used exceptions in my code and eclipse flagged my syntax as wrong:
try {
// code here
} catch (e if e instanceof MyException) {
// handle exception
I found this syntax in Mozilla's site
What's wrong?
Zohar.
Re: using instanceof in javascript [message #545536 is a reply to message #545369] Thu, 08 July 2010 04:12 Go to previous messageGo to next message
On 7/7/2010 10:27 AM, Zohar Amir wrote:
> Hello,
> my syntax as wrong:
> try {
> // code here
> // handle exception
> https://developer.mozilla.org/en/Core_JavaScript_1.5_Referen ce/Statements/try...catch
> What's wrong?
> Zohar.
How "close enough" is it really? I don't know JSFL, but does it also
document this construct as supported?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: using instanceof in javascript [message #545595 is a reply to message #545536] Thu, 08 July 2010 07:10 Go to previous messageGo to next message
Well, this construct works when I run it...
It's just that it's flagged as a syntax error by eclipse.
I'm new to using javascript - isn't this construct something normal?
Zohar
Re: using instanceof in javascript [message #546999 is a reply to message #545595] Wed, 14 July 2010 17:52 Go to previous messageGo to next message
Zohar Amir wrote:
> Well, this construct works when I run it... It's just that it's flagged
Note that the page you cite
says about conditional catch:
Note: This functionality is not part of the ECMAScript specification.
So I guess eclipse does not support it. (I've never seen it used).
jjb
> Zohar
Re: using instanceof in javascript [message #547518 is a reply to message #546999] Sun, 18 July 2010 02:37 Go to previous message
Hello John,
You're right of course, I just guessed Mozilla is a strong enough player to support this syntax, that they use.
Thank you for looking into this.
Zohar.
Previous Topic:[Web Service using WTP] HELP: error whit WebService wizard
Next Topic:Does WTP WSDL editor allow adding new tabs? If yes how?
Current Time: Thu Jul 24 22:34:17 EDT 2025
Powered by FUDForum. Page generated in 0.07459 seconds
