Home » Language IDEs » AspectJ » eclipse editor shows errors, but ITD works, how to fix
eclipse editor shows errors, but ITD works, how to fix [message #547488] Sat, 17 July 2010 11:26 Go to next message
I am using the 2.1.0 e3.5x release of AJDT. When I use an ITD in the eclipse editor, after creating a brand new AJDT project, the ITD shows editor errors pretty much for all types. However, the project runs fine so the compilation is okay.
It appears to be an editor integration issue.
Do I have a bad configuration/options setting somewhere?
Thoughts?
I would attach a screen shot but I do not see a file attachment button in the web interface for the forum.
[Updated on: Sat, 17 July 2010 11:28] by Moderator
Re: eclipse editor shows errors, but ITD works, how to fix [message #547504 is a reply to message #547488] Sat, 17 July 2010 16:56 Go to previous messageGo to next message
Two possibilities here:
1. you do not have JDT weaving enabled.
2. You are opening your Aspect file in a Java editor
Re: eclipse editor shows errors, but ITD works, how to fix [message #547513 is a reply to message #547504] Sat, 17 July 2010 22:17 Go to previous messageGo to next message
Looks like the editor is the issue. Weaving is enabled. Will look for the default editor setting in aspectj projects.
Thanks.
Re: eclipse editor shows errors, but ITD works, how to fix [message #547580 is a reply to message #547513] Mon, 19 July 2010 00:06 Go to previous messageGo to next message
If the editor does not seem to be the problem, you can send me a screenshot and a simple failing project directly:
andrew at eisenberg dot as
Re: eclipse editor shows errors, but ITD works, how to fix [message #601128 is a reply to message #547504] Sat, 17 July 2010 22:17 Go to previous messageGo to next message
Thanks.
Re: eclipse editor shows errors, but ITD works, how to fix [message #601139 is a reply to message #601128] Mon, 19 July 2010 00:06 Go to previous message
Previous Topic:eclipse editor shows errors, but ITD works, how to fix
Next Topic:"Deployable plug-ins and fragments with AspectJ support" missing in 3.6
Current Time: Sat Jul 26 19:15:38 EDT 2025
Powered by FUDForum. Page generated in 0.03966 seconds
