Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 1.3RC3: deadlock detected
RAP 1.3RC3: deadlock detected [message #539016] |
Wed, 09 June 2010 06:42  |
Hello Everybody,
Display.dispose and Display#isDisposed both acquire the Display#deviceLock.
The calls to Display#dispose and Display#isDisposed are in separate
threads (stacktrace follows).
Deadlock finally occurs in JobManager - JobManager#select and
JobManager#endJob both acquire the JobManager#lock.
Daemon Thread [UIThread [1mf5jlvjysproowtxhc1f0krn]] (Suspended)
JobManager.select(Object, int) line: 1158
JobManager.select(Object) line: 1148
JobManager.cancel(Object) line: 333
Workbench.cancelEarlyStartup() line: 2769
Workbench.shutdown() line: 2734
Workbench.busyClose(boolean) line: 870
Workbench.access$12(Workbench, boolean) line: 781
Workbench$21.run() line: 1047
BusyIndicator.showWhile(Display, Runnable) line: 66
Workbench.close(int, boolean) line: 1045
Workbench.close() line: 1007
Workbench$ShutdownHandler.handleEvent(Event) line: 131
Display.sendDisposeEvent() line: 714
Display.release() line: 693
Display(Device).dispose() line: 282
UIThread.processShutdown() line: 159
RWTLifeCycle$UIThreadController.run() line: 128
UIThread(Thread).run() line: 619
UIThread.run() line: 102
Thread [Worker-0] (Suspended)
Display(Device).isDisposed() line: 300
JobManagerAdapter.done(IJobChangeEvent) line: 119
JobListeners$3.notify(IJobChangeListener, IJobChangeEvent) line:39
JobListeners.doNotify(JobListeners$IListenerDoit, IJobChangeEvent)
line: 96
JobListeners.done(Job, IStatus, boolean) line: 152
JobManager.endJob(InternalJob, IStatus, boolean) line: 646
WorkerPool.endJob(InternalJob, IStatus) line: 105
Worker.run() line: 71
Dmitry
Re: RAP 1.3RC3: deadlock detected [message #539267 is a reply to message #539016] |
Thu, 10 June 2010 04:32   |
Hi Dmitry,
is this deadlock reproducible with your application or does it only
occur randomly? Can you provide some code or explain the preconditions
that cause the deadlock?
Regards, Ralf
Dmitry Pryadkin wrote:
> Hello Everybody,
> line: 96
> Dmitry
Re: RAP 1.3RC3: deadlock detected [message #539467 is a reply to message #539295] |
Thu, 10 June 2010 16:35   |
Hi Dmitry,
I can't currently reproduce a deadlock with your description. The UI
Threads always terminate properly, even when the browser is closed while
some jobs are still running.
If you can reproduce it, you should open a bug report but we'll need
some more information. The stacktraces alone will not be sufficient to
analyze the problem.
Regards, Ralf
> Hi Ralf,
> It happens with my application. I can't pin-point the situation within
> small project.
> Steps to reproduce:
> 1) Start Application
> 2) Open session
> 3) Do some things - populate Jobs in Jobmanager
> 4) Close browser
> 5) Wait for session invalidation
> 6) Some jobs (with JobListeners) left spinning in JobManager
> 8) The thread named "Worker-0" had attempted to end one of these jobs,
> but got caught in Display#isDisposed (see 2nd stacktrace).
> 9) In the same time the UI Thread was about to do Display#dispose (see
> 1st stacktrace).
> I don't know from where the "Worker-0" was created. But I believe it's
> from Workbench.
> Dmitry
> Ralf Sternberg wrote:
>> Hi Dmitry,
>> Regards, Ralf
>>> Hello Everybody,
>>> Display#deviceLock.
Re: RAP 1.3RC3: deadlock detected [message #671317 is a reply to message #669974] |
Tue, 17 May 2011 09:19  |
Hello again,
I had some time left for further investigations and I think I found our
problem.
Unfortunately the patch referenced in my former post wasn't successful.
But this gave me the chance to examine the stack traces again (attached).
The problem is that we have some kind of editable cells in a table. The
deadlock occur when:
1. The user enters a value into a editable table cell.
2. The user don't apply the change by pressing "return".
3. The session expires.
This leads to a ICellEditorListener#applyEditorValue(). This event
triggers a refresh of another derived ViewPart#refresh() object which is
another view of the same data model:
Daemon Thread [UIThread...:
TreeViewer(StructuredViewer).refresh() line: 1445
ConfigurationOverview.refresh() line: 386
ConfigurationOverview.configProblemsChanged() line: 133
ConfigurationListenerHandling.configProblemsChanged() line: 100
Configuration.validateConfiguration() line: 869
PropertyView$PropEditingSupport.setValue(Object, Object) line: 178
PropertyView$PropEditingSupport(EditingSupport).saveCellEdit orValue(CellEditor,
ViewerCell) line: 116
TableViewerEditor(ColumnViewerEditor).saveEditorValue(CellEd itor) line: 454
TableViewerEditor(ColumnViewerEditor).applyEditorValue() line: 310
This refresh triggers a DecorationScheduler#decorationJob#schedule()
which waits for "JobManager#lock" and locks "Device#deviceLock".
The same time the Worker-11 Thread waits for "Device#deviceLock" and
blocks "JobManager#lock".
I'm not sure if this is a problem of RAP or of a missing decoupling of
our views. I'll do further investigations. :-)
I hope this description might help some other users having similar problems.
Oliver
Complete stack traces:
__Worker Thread_______________________________
Thread [Worker-11] (Suspended)
owns: Object (id=14665)
waiting for: Object (id=14664)
owned by: Daemon Thread [UIThread
[62A33EC05149C56A5A094BAAE07985E6.localSlot2]] (Suspended)
waiting for: Object (id=14665)
owned by: Thread [Worker-11] (Suspended)
JobListeners$3.notify(IJobChangeListener, IJobChangeEvent) line: 39
line: 96
JobManager.endJob(InternalJob, IStatus, boolean) line: 647
JobManager.startJob() line: 1488
WorkerPool.startJob(Worker) line: 218
Worker.run() line: 50
__UI Thread_______________________________
Daemon Thread [UIThread [62A33EC05149C56A5A094BAAE07985E6.localSlot2]]
(Suspended)
owns: DecorationScheduler (id=14663)
owns: Object (id=14664)
JobManager.schedule(InternalJob, long, boolean) line: 1109
DecorationScheduler$4(InternalJob).schedule(long) line: 427
DecorationScheduler$4(Job).schedule() line: 436
DecorationScheduler$2.run() line: 177
FakeContextUtil.runNonUIThreadWithFakeContext(Display, Runnable) line: 60
UICallBack.runNonUIThreadWithFakeContext(Display, Runnable) line: 48
DecorationScheduler.queueForDecoration(Object, Object, boolean, String,
IDecorationContext) line: 175
DecoratorManager.prepareDecoration(Object, String, IDecorationContext)
line: 1141
DecoratorManager$ManagedWorkbenchLabelDecorator.prepareDecor ation(Object, String, IDecorationContext) line: 177
DecoratingLabelProvider.updateLabel(ViewerLabel, TreePath) line: 327
WrappedViewerLabelProvider.update(ViewerCell) line: 183
ColumnViewer$3(ViewerColumn).refresh(ViewerCell) line: 153
TreeViewer(AbstractTreeViewer).doUpdateItem(Item, Object) line: 916
AbstractTreeViewer$UpdateItemSafeRunnable.run() line: 102
SafeRunner.run(ISafeRunnable) line: 42
Platform.run(ISafeRunnable) line: 888
JFaceUtil$1.run(ISafeRunnable) line: 50
SafeRunnable.run(ISafeRunnable) line: 175
TreeViewer(AbstractTreeViewer).doUpdateItem(Widget, Object, boolean)
line: 996
StructuredViewer$UpdateItemSafeRunnable.run() line: 481
TreeViewer(StructuredViewer).updateItem(Widget, Object) line: 2142
TreeViewer(AbstractTreeViewer).updateChildren(Widget, Object, Object[],
boolean) line: 2671
TreeViewer(AbstractTreeViewer).internalRefreshStruct(Widget, Object,
boolean) line: 1849
TreeViewer.internalRefreshStruct(Widget, Object, boolean) line: 717
boolean) line: 1856
TreeViewer(AbstractTreeViewer).internalRefresh(Widget, Object, boolean,
boolean) line: 1824
TreeViewer(AbstractTreeViewer).internalRefresh(Object, boolean) line: 1781
TreeViewer(AbstractTreeViewer).internalRefresh(Object) line: 1767
StructuredViewer$7.run() line: 1488
TreeViewer(StructuredViewer).preservingSelection(Runnable, boolean)
line: 1423
TreeViewer.preservingSelection(Runnable, boolean) line: 403
TreeViewer(StructuredViewer).preservingSelection(Runnable) line: 1384
TreeViewer(StructuredViewer).refresh(Object) line: 1486
TreeViewer(ColumnViewer).refresh(Object) line: 547
PropertyView$PropEditingSupport(EditingSupport).saveCellEdit orValue(CellEditor, ViewerCell) line: 116
line: 454
ColumnViewerEditor$2.applyEditorValue() line: 152
CellEditor$1.run() line: 329
TextCellEditor(CellEditor).fireApplyEditorValue() line: 327
TextCellEditor(CellEditor).focusLost() line: 708
TextCellEditor$5.focusLost(FocusEvent) line: 184
FocusEvent.dispatchToObserver(Object) line: 70
FocusEvent(Event).processEvent() line: 44
FocusEvent(TypedEvent).processEvent() line: 161
Display.setFocusControl(Control) line: 287
Display.access$3(Display, Control) line: 282
Display$DisplayAdapter.setFocusControl(Control) line: 2247
Composite(Control).setFocusControl(Control) line: 2127
Composite(Control).forceFocus() line: 758
Composite(Control).setFixedFocus() line: 2182
Composite(Control).fixFocus(Control) line: 2165
Composite(Control).setVisible(boolean) line: 259
WorkbenchPage.onDeactivate() line: 2508
WorkbenchWindow$22.run() line: 2912
WorkbenchWindow.setActivePage(IWorkbenchPage) line: 2907
WorkbenchWindow.closeAllPages() line: 798
WorkbenchWindow.hardClose() line: 1635
WorkbenchWindow.busyClose() line: 683
WorkbenchWindow.access$0(WorkbenchWindow) line: 659
WorkbenchWindow$2.run() line: 775
WorkbenchWindow.close() line: 773
WindowManager.close() line: 109
Workbench$13.run() line: 861
Workbench.busyClose(boolean) line: 858
RWTLifeCycle$UIThreadController.run() line: 139
Current Time: Sat Jul 26 18:55:27 EDT 2025
Powered by FUDForum. Page generated in 0.06786 seconds
