[MWE2] How to run from command line? [message #546510] |
Tue, 13 July 2010 04:43  |
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hello all,
somehow I can't figure out the proper way to run an MWE2 from the
command line on my Linux system, using Eclipse Helios:
java -Xms128m -Xmx1024m -XX:MaxPermSize=256m -jar
/local/dhendriks/eclipse/plugins/org.eclipse.equinox.launche r_1.1.0.v20100507.jar
-nosplash -application org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner
<absolute path to my mwe2 file parent dir>/GenerateCifText.mwe2
When I execute this line from the command line, it thinks for about a
second and then returns to the prompt. There is no output, and it didn't
generate the code using the xtext file (that's what the MWE2 is supposed
to do).
Obviously everything works just fine from Eclipse UI.
Does anyone know what I'm doing wrong?
Dennis
FUDForum. Page generated in 0.03305 seconds
