Home » Archived » BIRT » Upgrade Birt Engine 2.3.2 to 2.6(Upgrade Birt Engine 2.3.2 to 2.6)
icon5.gif  Upgrade Birt Engine 2.3.2 to 2.6 [message #544692] Mon, 05 July 2010 05:43 Go to next message
Hi All
i have a task to upgrade the Birt Engine that already installed on our application, what we have now Birt version 2.3.2 and ineed to upgrade it to the new release 2.6 ?
my questions , which jars i need to replace them or i need to replace all the runtime folder?
best regards
[Updated on: Mon, 05 July 2010 08:50] by Moderator
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #545043 is a reply to message #544692] Tue, 06 July 2010 10:00 Go to previous messageGo to next message
Are you upgrading the viewer or just the engine? If you are replacing
the engine just download the 2.6 runtime and replace your current
birt-runtime-2_3_2\ReportEngine\lib with
birt-runtime-2_6_0\ReportEngine\lib and your
birt-runtime-2_3_2\ReportEngine\plugins with
birt-runtime-2_6_0\ReportEngine\plugins. Also delete
birt-runtime-2_3_2\ReportEngine\configuration directory and replace it
with birt-runtime-2_6_0\ReportEngine\configuration.
Jason
On 7/5/2010 5:43 AM, Wael Mashal wrote:
> Hi All
> best regards
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #545340 is a reply to message #545043] Wed, 07 July 2010 09:30 Go to previous messageGo to next message
until now I was using birt-runtime-2_5_1.
I just downloaded the birt-runtime-2_6_0. When I run my application I get the following error:
Jul 7, 2010 3:25:15 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet jsp threw exception
java.lang.NoSuchMethodError: org.eclipse.birt.report.engine.api.EngineConfig.getLogRollin gSize()I
at org.eclipse.birt.report.engine.api.impl.ReportEngine.intiali zeLogger(ReportEngine.java:221)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:133)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:18)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:1)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createReportEngine(ReportEngineFactory.java:14)
at com.qmplus.common.util.birt.BirtEngine.createEngineInstance( BirtEngine.java:122)
at com.qmplus.common.util.birt.BirtEngine.getBirtEngine(BirtEng ine.java:39)
I even tried the birt-runtime-2_5_2 but then I got another error:
Jul 7, 2010 3:12:01 PM org.apache.catalina.core.StandardWrapperValve invoke
java.lang.NoSuchMethodError: org.eclipse.birt.report.engine.api.EmitterInfo.setOverridePr iority(I)V
at org.eclipse.birt.report.engine.extension.internal.ExtensionM anager.loadEmitterExtensionDefns(ExtensionManager.java:629)
at org.eclipse.birt.report.engine.extension.internal.ExtensionM anager. <init>(ExtensionManager.java:148)
at org.eclipse.birt.report.engine.extension.internal.ExtensionM anager.createInstance(ExtensionManager.java:161)
at org.eclipse.birt.report.engine.extension.internal.ExtensionM anager.getInstance(ExtensionManager.java:170)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.<init >(ReportEngineHelper.java:81)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:136)
Is there some compatibility issue between birt-runtime versions? I tried deleting
everything in WEB-INF\platform\configuration except
the config.ini file as was suggested in another thread for a similar problem, but nothing changed. Any suggestions?
Thanks!
Katerina
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #547181 is a reply to message #544692] Thu, 15 July 2010 16:19 Go to previous messageGo to next message
I am trying to do the same thing, upgrade from 2.3.0 to 2.6. Does anyone what I have to do to get it up and running with 2.6?
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #547372 is a reply to message #547181] Fri, 16 July 2010 09:33 Go to previous messageGo to next message
Did you try:
Jason
Re: Upgrade Birt Engine 2.3.2 to 2.6 [message #547381 is a reply to message #547372] Fri, 16 July 2010 10:22 Go to previous message
I took all the plugins/configurations/lib files in the2.6 report viewer and copied them over the old 2.3.0 files that were in are web app. It seems that we have integrated 2.3.0 report viewer with are app. I just replaced all the 2.3 with 2.6 report viewer jar's/jsp's and it worked.
Well it looks what I did is what you told me to do. This was just to see if going to 2.6 would clear up some other out standing problems.
The other thing that I noticed is, with 2.3.0 you could have a data type of any and now, 2.6 do not like this, however from what I have tested, It seems to still work.
[Updated on: Fri, 16 July 2010 10:26] by Moderator
Previous Topic:DataSource Property Binding
Next Topic:Firewall Issues? [2.3.2]
Current Time: Wed Jul 23 11:40:32 EDT 2025
Powered by FUDForum. Page generated in 0.73531 seconds
