Firewall Issues? [2.3.2] [message #546918] |
Wed, 14 July 2010 11:34  |
In our setup, we have a firewall (Microsoft ISA) running on a machine with a public IP address and we have enabled port forwarding as BIRT runs on a local server (Tomcat 6.0.20).
We have no issues running/viewing reports on the LAN. For instance, we can access BIRT reports like this:
http://reportserver:9090/birt/frameset?__report=report/app/a cct_stmt.rptdesign&id=1001&from_date=2010-01-01& to_date=2010-07-14
(Note that this is done via a GUI application that runs on the same machine as BIRT, so users don't have to enter the URL manually. They can log into this application and navigate it from outside successfully via the firewall with the public IP Address).
However, reports cannot be run from outside using, for instance, the following URL:
http://public_ip/birt/frameset?__report=report/app/acct_stmt .rptdesign&id=1001&from_date=2010-01-01&to_date= 2010-07-14.
(where public_ip is the public IP Address assigned to the firewall machine)
When a user attempts to run a report, nothing shows up and the browser just keeps loading... In Firebug I can see that the first request to /birt/frameset is OK. However, the first request that BIRT makes goes to http://192.168.0.4:9090/birt/webcontent/birt/styles/style.cs s, which is our local server! And of course there are other additional requests (for stylesheets and javascript files) which also go to the local server.
What could be wrong? Has anyone successfully deployed BIRT in the way and manner that we've tried to?
Re: Firewall Issues? [2.3.2] [message #546967 is a reply to message #546918] |
Wed, 14 July 2010 14:30   |
Paul
Can you try the /preview mapping instead of the frameset mapping as a test?
Jason
> following URL:
Re: Firewall Issues? [2.3.2] [message #547374 is a reply to message #547202] |
Fri, 16 July 2010 09:38   |
Paul,
I am not certain this is a bug, but I think you need to log it and maybe
you can get a work around through bugzilla. It is odd to me that
/preview mapping also uses style sheets and does not error.
Jason
On 7/15/2010 6:25 PM, PaulK wrote:
> Jason, thanks for your response but I don't understand why the fact that
> BIRT uses webservices to get data would cause it to behave this way.
> Unless there's something I"m missing.
> What I expect to happen is that as requests come from the Internet and
> are forwarded to BIRT via the firewall, the response coming from BIRT
> should also go back to the user's browser via the firewall. However, the
> browser gets stuck while trying to make requests to BIRT's stylesheets
> and javascript files. This as I said, happens via the local ip address
> of the machine BIRT is running on (I can see this clearly in Firebug).
> It's as though the firewall isn't there at all. My browser should never
> make a request to a machine behind a firewall directly, even if it did
> it should be transparent to me. Would you describe this as a bug? Is
> there something to configure in BIRT somewhere? A work-around maybe?
> Anyway, if you're certain it's a bug, I'll go ahead and file it.
Re: Firewall Issues? [2.3.2] [message #547392 is a reply to message #547374] |
Fri, 16 July 2010 10:43  |
Hi Jason,
There's a similar bugzilla entry for 2.3.2 as: Bug 319578 - BIRT viewer doesn't work with VPN.
It's close to what I'm experiencing. I can run reports using the /run mapping with the __format parameter set to pdf, for instance, but then that's not really what I want as users won't have the other Viewer options at their disposal.
I'll add additional comments to the existing bug report. Thanks.
FUDForum. Page generated in 0.07260 seconds
