Home » Eclipse Projects » Eclipse Platform » Menu visible when selection is a subclass of StructuredSelection(visibleWhen on subtypes of StructuredSelection)
Menu visible when selection is a subclass of StructuredSelection [message #546977] Wed, 14 July 2010 15:34 Go to next message
I have a class: MyStructuredSelection (extends StructuredSelection).
Under certain circumstances I set the selection as an instance of MyStructuredSelection using:
getSite.getSelectionProvider.setSelection(new MyStructuredSelection(...))
I would like to have certain menu contributions visible only when the selection is an instance of MyStructuredSelection.
Is there a way to do set menu visibility based on the type of the selection?
Thank you
Mark Lovell
Re: Menu visible when selection is a subclass of StructuredSelection [message #547069 is a reply to message #546977] Thu, 15 July 2010 08:12 Go to previous messageGo to next message
Do you mean org.eclipse.ui.menus/menuContributions? visibleWhen (core
expressions) supports <instanceof />
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Menu visible when selection is a subclass of StructuredSelection [message #547129 is a reply to message #547069] Thu, 15 July 2010 11:58 Go to previous messageGo to next message
Thank you for replying.
Yes I am using org.eclipse.ui.menus/menuContributions.
The visibleWhen processes the objects in the selection's list (selection.toList()) not the selection object (ISelection) itself.
Therefore "instanceof" acts on the objects within the selection's list.
I am hoping to find a way to set a menu's visbility based on the type of the selection (ex MyStructuredSelection extends StructuredSelection) regardless of the objects it contains.
Thoughts?
Re: Menu visible when selection is a subclass of StructuredSelection [message #547158 is a reply to message #547129] Thu, 15 July 2010 13:29 Go to previous messageGo to next message
use <variable with="selection"... or <variable
with="activeMenuSelection" as appropriate.
The default variable for visibleWhen is a Collection with the contents
of the selection.
PW
Paul Webster
Re: Menu visible when selection is a subclass of StructuredSelection [message #547161 is a reply to message #547158] Thu, 15 July 2010 14:05 Go to previous message
variable with="selection"... works perfectly.
Thank you very much
Very Happy
Previous Topic:Lauch Configuration
Next Topic:The project was not built since the source file ... could not be read
Current Time: Sat Jul 26 19:06:10 EDT 2025
Powered by FUDForum. Page generated in 0.06280 seconds
