[Eugenia] Problem with tool.name annotation detail by using different metamodel [message #547112] |
Thu, 15 July 2010 09:27  |
Originally posted by: mario28988.yahoo.de
Hi newsgroup,
I have created the following metamodel which extends the general ecore
metamodel:
example
|- DiagramElement -> EClass
|- ModelElement -> EClass
|- EditorProject -> EPackage
Based on this metamodel I have created a model with gmf annotations:
Editor Project TestProject
|- gmf
|- Model Element AModelElement
|- name : String
|- gmf.node
|- label -> name
|- tool.name -> NewToolName
|- Diagram Element ADiagramElement
|- gmf.diagram
|- ownedModelElements : AModelElement
|- gmf.link
|- tool.name
My Problem is, that if I generate the gmf models via eugenia only the
tool name of the link element will be changed (not the node tool name).
Referring to this I checked the Ecore2GMF.eol script of the
org.eclipse.epsilon.eugenia plugin and located the problem in the
createCreationTool operation. The condition of the if statement 'if
(element.isTypeOf(ECore!EClass) and element.isNode())' always returns
false, because the element type isn't exactly EClass but AModelElement
(which is derived from EClass). However, the isTypeOf method returns
false. :-(
Is this behaviour a problem of the isTypeOf method or should the
implementation of the Ecore2GMF.eol be different? Does anyone know the
location of the eol api reference according to this?
What would you advise me in this issue? What's a 'good' solution for
this problem?
Thanks in advance.
Mario
FUDForum. Page generated in 0.03985 seconds
