Re: Data cube: add another column for aggregation [message #547126 is a reply to message #547113] |
Thu, 15 July 2010 11:48   |
Editing my cube in summary field (measures) I don't see AVG function,
but SUM, MAX, MIN, FIRST, LAST, COUNT, COUNTDISTINCT.
I have set SUM, but I also need AVG.
Thank you
Nicola
Jason Weathersby ha scritto:
> Nicola.
> Do you have Average as a cube measure?
> Jason
> On 7/15/2010 5:39 AM, nicola wrote:
>> Hi,
>> in my cubo I have my data (for month) and at right I add a Grand Total.
>> Now I need to add a further column with Average.
>> How can I do that, please?
>> Thank you
>> Nicola
Re: Data cube: add another column for aggregation [message #547373 is a reply to message #547305] |
Fri, 16 July 2010 09:35  |
Yes that is a work around. Can you add an enhancement bugzilla entry?
Jason
On 7/16/2010 5:00 AM, nicola wrote:
> it works, but that seem to me workaround. So far as I understood it's
> not possible to add a further column to Grand Total.
> May be should I add a feature enhance?
> Thank you,
> Nicola
>> You should be able to drag an aggregation report item from the palette
>> to the grand total column and build its expression to do the average. By
>> default this will put the average below the grand total field. Set the
>> style for the grand total and the new aggregation fields to use Text
>> Block->Display->Inline
>> Jason
>> On 7/15/2010 12:13 PM, nicola wrote:
>>> What I'd like to get is a report like this:
>>> MY_PARAM JAN(SUM) FEB(SUM) MAR(SUM) APR ...GRAND_TOTAL AVERAGE_IN_YEAR
>>> Cheers,
>>> Nicol
FUDForum. Page generated in 0.05309 seconds
