Home » Archived » BIRT » Viewer web.xml being ignored in 2.5.2?(Changes to web.xml seem to have no effect in the viewer.)
Viewer web.xml being ignored in 2.5.2? [message #546706] Tue, 13 July 2010 16:55 Go to next message
I've been attempting to change $BIRT_HOME/plugins/org.eclipse.birt.report.viewer_2.5.2.v200 91210/birt/WEB-INF/web.xml to point it to my scriptlib directory but it seems to be ignoring my change when I view a report in BIRT. I get lots of errors saying the event handlers can't be found. The same change works fine in BIRT 2.3.2. I've double-checked the directory and the jars in it. Everything is valid. I've tried changing a few other things also, such as the logging level and the max rows but everything seems to be ignored.
Has anyone else done this sort of thing in 2.5.2 and can you confirm if it really is a problem or if I'm imagining things?
Re: Viewer web.xml being ignored in 2.5.2? [message #546729 is a reply to message #546706] Tue, 13 July 2010 20:34 Go to previous messageGo to next message
Steve,
I thought this bug was already logged but I can not seem to locate it.
I believe it had to do with logging level which you can set in the
viewer.properties. This is not the case for scriptlib. Any chance you
can open a bug for this?
Jason
> ignored.
Re: Viewer web.xml being ignored in 2.5.2? [message #546957 is a reply to message #546729] Wed, 14 July 2010 13:49 Go to previous message
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=319859
FYI: I think we've decided to work around this by using the project-specific classpath preference.
Previous Topic:Problem with Tables
Next Topic:The nested tables with the XML source?
Current Time: Fri Jul 25 19:22:30 EDT 2025
Powered by FUDForum. Page generated in 0.24864 seconds
