Home » Archived » BIRT » Problem with Tables
Problem with Tables [message #546436] |
Mon, 12 July 2010 14:30  |
Originally posted by: pschoenb.gmx.de
I am quite new to BIRT, and I am building a report using scripting.
Although I was able to build a simple example successfully, I have
problems in my main app to get anything displayed in a table.
To find out what is happening, I installed a row event handler. I
noticed that onPrepare() gets called, but onCreate() and onRender()
never is called.
I checked my dataset and it seems that the data is filled in correctly.
What could be wrong?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: Problem with Tables [message #546568 is a reply to message #546550] |
Tue, 13 July 2010 07:25   |
On Tue, 13 Jul 2010 12:38:22 +0200, Patrick Schönbach wrote:
> On Mon, 12 Jul 2010 16:06:26 -0400, Jason Weathersby wrote:
>> Are you sure the table is bound to the dataset? Look at the binding tab
>> in the properties editor.
> Yes, the table *is* bound to the dataset.
For the table, onPrepare(), onCreate() and onRender() is called
correctly. However, for the detail row, only onPrepare() is called. Due
to some unfortunate dependency, I am stuck with Eclipse 3.3 and BIRT
2.2.2.
Patrick
Re: Problem with Tables [message #546606 is a reply to message #546568] |
Tue, 13 July 2010 10:18   |
Can you post the report?
> 2.2.2.
Re: Problem with Tables [message #546727 is a reply to message #546606] |
Tue, 13 July 2010 19:47  |
Patrick,
I looked at your report. Where do you have the dataset eventhandler
class located?
Are you sure it is being called? The row event adapter will not be
called if no rows are available in the dataset.
Jason
>> 2.2.2.
Current Time: Wed Jul 23 08:51:36 EDT 2025
Powered by FUDForum. Page generated in 0.05881 seconds
