Home » Eclipse Projects » Remote Application Platform (RAP) » could not evaluate javascript response: Invalid characters?(rap Invalid characters charset=unicode)
could not evaluate javascript response: Invalid characters? [message #546403] Mon, 12 July 2010 12:16 Go to next message
Hi all experts,
I wrote a RAP application and deployed it to tomcat running on a Linux OS.
The problem is that when I restart the service and try to start a new sesssion, The IE explorer get the error message that "could not evaluate javascript response: Invalid characters"
The problem cannot be reproduced every time when restart the service.
When this problem occurs, I reopen a new IE explorer, and it works fine.
I saved the error page and tracked the source code of the html file, finding that the parameter of charset might be probably wrong:
"<meta http-equiv="Content-Type" content="text/html;charset=unicode" />".
The parameter "charset" there was set to "unicode" while in cases the application runs well it is set to "UTF-8".
Could you please have a glance on this problem?
Thanks and Best Regards!
Re: could not evaluate javascript response: Invalid characters? [message #546410 is a reply to message #546403] Mon, 12 July 2010 12:35 Go to previous messageGo to next message
it sounds like this bug:
298181: [encoding problem] encoding of the initial html page is not
specified, and thus is not always utf-8
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298181
which has been fixed in RAP 1.3M5 and backported to maintenance branch
1.2.2.
Which version of RAP are you using?
Best,
Ivan
On 07/12/2010 7:16 PM, lyp wrote:
> Hi all experts,
> OS.
Re: could not evaluate javascript response: Invalid characters? [message #546476 is a reply to message #546410] Mon, 12 July 2010 22:39 Go to previous messageGo to next message
Thanks a lot, Ivan
The RAP version I am using is 1.2.0
I will use this patch and try to verify it.
And only update the class of JSLibraryServiceHandler.java?
RWTDelegate.java is not need to update?
Best Regards!
Re: could not evaluate javascript response: Invalid characters? [message #546496 is a reply to message #546476] Tue, 13 July 2010 02:54 Go to previous messageGo to next message
For the needs of bug 298181 only JSLibraryServiceHandler has been
updated, yes.
If you still have problems after the patch, please feel free to open a
separate bug with a snippet to reproduce it.
Best,
Ivan
On 07/13/2010 5:39 AM, lyp wrote:
> Thanks a lot, Ivan
> Best Regards!
Re: could not evaluate javascript response: Invalid characters? [message #546635 is a reply to message #546496] Tue, 13 July 2010 11:23 Go to previous messageGo to next message
Thanks Ivan.
I am sorry to say that my RAP application still has the problem after using the patch.
Re: could not evaluate javascript response: Invalid characters? [message #547332 is a reply to message #546635] Fri, 16 July 2010 06:16 Go to previous messageGo to next message
did you apply the patch yourself or did you try out the 1.2.2 release?
Ben
lyp wrote:
> Thanks Ivan.
> using the patch.
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: could not evaluate javascript response: Invalid characters? [message #547333 is a reply to message #547332] Fri, 16 July 2010 06:50 Go to previous message
Hi Benjamin,
Yes, I apply the patch myself.
The RAP version I am using is 1.2.0.
and I have not try to use the 1.2.2 release.
You mean the problem is solved in RAP 1.2.2 and RAP1.3.
I will try to check it in RAP1.3
Best Regards
Previous Topic:[Display].timerExec() not executed when expected (as RCP does)
Next Topic:Seems like the UICallBack mechanism get broken
Current Time: Sun Jul 27 11:56:22 EDT 2025
Powered by FUDForum. Page generated in 0.07702 seconds
