Home » Modeling » Epsilon » [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
[Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546117] Sun, 11 July 2010 06:06 Go to next message
--------------080301040803050308020009
Hi all,
I just recently heard from Eugenia, and I wanted to test it to see
how it worked. So I followed the tutorial from
http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-gmf- tutorial/
and the corresponding screencast from
http://www.eclipse.org/gmt/epsilon/cinema/Eugenia.htm
I have had problems with the annotations which do not have
properties, so I solved the problems creating the foo property, as it is
written in the tutorial(I've read in a previous post that this problem
is due to the emfatic version), so I have written the annotations
@gmf(foo="bar"), and @gmf.diagram(foo="bar"), and
@gmf.compartment(foo="bar").
However, when I follow the whole process to generate the editor, and
I test the generated editor, the item Folder is disabled. That is, I can
not create any folder, and as you can see in the image file I have
attached, there is no icon associated to Folder.
I also have tried to change the Folder annotation to set the default
values of the properties:
class Folder extends File {
@gmf.compartment(layout="free",collapsible="true")
val File[*] contents;
But the problems remains the same, that is, I can not create folders.
Any idea of the problem?
Thanks and regards,
To
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546119 is a reply to message #546117] Sun, 11 July 2010 06:45 Go to previous messageGo to next message
Hi Toni,
Thanks for reporting this. This seems to be a regression introduced in
the latest version of Epsilon. Could you please file a bug report for
this using the link below?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
Dimitris
On 11/07/2010 11:06, Toñi Reina Quintero wrote:
> Hi all,
> I just recently heard from Eugenia, and I wanted to test it to see how
> I have had problems with the annotations which do not have properties,
> so I solved the problems creating the foo property, as it is written in
> the tutorial(I've read in a previous post that this problem is due to
> the emfatic version), so I have written the annotations @gmf(foo="bar"),
> and @gmf.diagram(foo="bar"), and @gmf.compartment(foo="bar").
> However, when I follow the whole process to generate the editor, and I
> Thanks and regards,
> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546121 is a reply to message #546119] Sun, 11 July 2010 07:51 Go to previous messageGo to next message
Hi Toni,
I've fixed this and uploaded a new interim version under
http://download.eclipse.org/modeling/gmt/epsilon/interim/
Thanks again for reporting this!
Dimitris
On 11/07/2010 11:45, Dimitris Kolovos wrote:
> Hi Toni,
> Cheers,
> Dimitris
>> Hi all,
>> Thanks and regards,
>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546131 is a reply to message #546121] Sun, 11 July 2010 09:53 Go to previous messageGo to next message
You're wellcome.
I'm happy to see that the problem is not due to the way I'm doing things.
As you have fixed the problem. Do you still want me to file the bug report?
Toñi
Dimitris Kolovos escribió:
> Hi Toni,
> Cheers,
> Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi all,
>>> Thanks and regards,
>>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546132 is a reply to message #546131] Sun, 11 July 2010 10:00 Go to previous messageGo to next message
Hi Toni,
On 11/07/2010 14:53, Toñi Reina Quintero wrote:
> You're wellcome.
Yes please.
> Regards,
> Toñi
Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi Toni,
>>> Cheers,
>>> Dimitris
>>>> Hi all,
>>>> @gmf(foo="bar"),
>>>> Thanks and regards,
>>>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546143 is a reply to message #546132] Sun, 11 July 2010 11:39 Go to previous messageGo to next message
--------------060401060207020708040305
Hi Dimitris,
I have reported the bug and tested the new version. Now it works :-)
Just a question more. When I create a Filesystem Diagram in the new
generated editor (it also happened with the old version), an error
attached to the .filesystem_diagram file is reported in the Project
Explorer, saying that there is no label provided for
filesystem.diagram.navigator.FileSystemNavigatorI. You can see the error
in the image file I have attached.
Why is the editor reporting this error? Is there any property that has
not been set in the .emf file?
Thanks again, and regards.
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #546168 is a reply to message #546143] Sun, 11 July 2010 18:53 Go to previous message
Hi Toni,
Many thanks for confirming that the new version works for you! Regarding
the error label, this is not something controlled by EuGENia. I've also
come across this but never had the motivation to look into it in detail.
Please consider reporting on the solution (when you've found one) here
for the benefit of other users who may come across the same issue in the
future.
Dimitris
> Hi Dimitris,
>> Hi Toni,
>>> You're wellcome.
>>> things.
>>> report?
>> Yes please.
>>> Regards,
>>> Toñi
>> Cheers,
>> Dimitris
>>>> Hi Toni,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Toni,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> Hi all,
>>>>>> how
>>>>>> properties,
>>>>>> written in
>>>>>> @gmf(foo="bar"),
>>>>>> and I
>>>>>> can
>>>>>> Thanks and regards,
>>>>>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #590584 is a reply to message #546117] Sun, 11 July 2010 06:45 Go to previous message
Hi Toni,
Dimitris
> Hi all,
> Thanks and regards,
> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #590594 is a reply to message #546119] Sun, 11 July 2010 07:51 Go to previous message
Hi Toni,
Dimitris
> Hi Toni,
> Cheers,
> Dimitris
>> Hi all,
>> Thanks and regards,
>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #590608 is a reply to message #546121] Sun, 11 July 2010 09:53 Go to previous message
You're wellcome.
Toñi
> Hi Toni,
> Cheers,
> Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi all,
>>> Thanks and regards,
>>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #590612 is a reply to message #546131] Sun, 11 July 2010 10:00 Go to previous message
Hi Toni,
> You're wellcome.
Yes please.
> Regards,
> Toñi
Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi Toni,
>>> Cheers,
>>> Dimitris
>>>> Hi all,
>>>> @gmf(foo="bar"),
>>>> Thanks and regards,
>>>> Toñi
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #590624 is a reply to message #546132] Sun, 11 July 2010 11:39 Go to previous message
Hi Dimitris,
Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item. [message #590630 is a reply to message #546143] Sun, 11 July 2010 18:53 Go to previous message
Hi Toni,
future.
Dimitris
> Hi Dimitris,
>> Hi Toni,
>>> You're wellcome.
>>> things.
>>> report?
>> Yes please.
>>> Regards,
>>> Toñi
>> Cheers,
>> Dimitris
>>>> Hi Toni,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Toni,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> Hi all,
>>>>>> how
>>>>>> properties,
>>>>>> written in
>>>>>> @gmf(foo="bar"),
>>>>>> and I
>>>>>> can
>>>>>> Thanks and regards,
>>>>>> Toñi
Previous Topic:[Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
Next Topic:[Eugenia] Problem generating the Diagram.
Current Time: Sun Jul 27 03:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.26044 seconds
