How to set column i.e. text field values from DataSetEventAdapter [message #545710] |
Thu, 08 July 2010 13:07  |
Originally posted by: pschoenb.gmx.de
I am trying to implement a Java-based event handler for a data set.
However, I do not understand how to write to a text field/list
cell/table cell from the onFetch() method, yet?
Are there any examples out there?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545944 is a reply to message #545943] |
Fri, 09 July 2010 12:31   |
Have you dragged the dataset on to the report canvas? Datasets do not
run unless they are bound to a report item (table/chart/etc).
Jason
On 7/9/2010 12:23 PM, Patrick Schönbach wrote:
> On Fri, 09 Jul 2010 10:54:20 -0400, Jason Weathersby wrote:
>> From a dataset event handler you do not write to a text filed. It is
>> just used to populate the dataset. You can then drag the dataset to the
>> report or drag individual columns to an existing table/gird. Every
>> table in a birt report is bound to a dataset (look at the binding tab in
>> the properties editor) which will do the evaluation automatically. If
>> you can give some more details I can help with an example.
> Jason,
> meanwhile, I found out that I have to extend ScriptedDataSetEventAdapter
> and overwrite fetch().
> However, I am still puzzled how to actually get the data into the
> dataset. I tried
> row.setColumnValue(columnName, someString);
> BIRT does generate some PDF, but except for the footer that I've put
> into the master page, I get empty pages.
> What am I missing?
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545980 is a reply to message #545963] |
Fri, 09 July 2010 14:45  |
Patrick,
I sent you an email with an example. Can you try it?
Jason
> Yes, I dragged one dataset element just into the report, and another
> into the header cell of a list, but both do not display.
> What could I be missing?
FUDForum. Page generated in 0.05651 seconds
