Information: breakpoints stop working when using xdebug with PDT. [message #545632] |
Thu, 08 July 2010 09:13 |
Originally posted by: dkel50.hotremovemail.com
There has been a lot of queries regarding breakpoints not working with
PDT when using xdebug or they were working but for some reason stopped
working.
In PDT 2.1 it looks like information was not being correct saved to hard
disk in regard to breakpoints. That meant that you can create a
breakpoint and it would work, but if you shutdown PDT and restart it
then the breakpoint would not work.
People also found a similar situation when initially migrating from PDT
2.1 to PDT 2.2
The solution is to delete all breakpoints and recreate them after
starting PDT 2.1 every time.
The problem looks like it is fixed in PDT 2.2 (ie breakpoint information
is persisted correctly), so when migrating from PDT 2.1 to PDT 2.2 you
just need to delete all breakpoints once.
Dave Kelsey
FUDForum. Page generated in 0.03700 seconds
