Home » Archived » Buckminster » p2.site of a feature contains wrong plugin versions
p2.site of a feature contains wrong plugin versions [message #545590] Thu, 08 July 2010 06:25 Go to next message
Hi!
I've some problems concerning plugin-versions when invoking "p2.site" on
a feature.
It seems that buckminster packs the newest plugin always even if the
feature.xml explicitely denotes a lower plugin version.
Example:
Feature org.eclipse.help (version 1.1.1.R35x_v20090811) lists the plugin
org.apache.commons.logging with version 1.0.4.v200904062259.
My target platform contains this plugin twice - once with this version
and once with version 1.1.1.v200904062255.
When I now invoke "p2.site" on this feature, the resulting p2 repository
contains only the newest version of org.apache.commons.logging.
As a result, installing this feature via director fails.
Can somebody please verify if this is a bug so that I can file it in
bugzilla?
(I'm using org.eclipse.buckminster.core.feature, version 1.3.0.r11467)
Mario
Re: p2.site of a feature contains wrong plugin versions [message #545592 is a reply to message #545590] Thu, 08 July 2010 06:53 Go to previous messageGo to next message
I have the same problem.
In my case commons.logging is even present in 3 different jars (2x1.0.4 and 1.1.1)...
If I use buckminster 3.5 there will be no problem...
Re: p2.site of a feature contains wrong plugin versions [message #545614 is a reply to message #545592] Thu, 08 July 2010 08:33 Go to previous messageGo to next message
Am 08.07.2010 12:53, schrieb Erdal Karaca:
> and 1.1.1)...
I've found out that it also works with buckminster 3.6 headless.
I've got the following warning when materializing into my workspace via
component query, but apart from that it works without errors:
WARNING [0000] : Component request
org.apache.commons.logging:osgi.bundle/[1.1.0,1.2.0) is inconflict with
request org.apache.commons.logging:osgi.bundle/[1.0.0,1.1.0)
Re: p2.site of a feature contains wrong plugin versions [message #545615 is a reply to message #545614] Thu, 08 July 2010 08:35 Go to previous messageGo to next message
Am 08.07.2010 14:33, schrieb Mario Winterer:
>> and 1.1.1)...
Additional info: It works with headless buckminster 3.6 M6; I've not
tried the final release!
Re: p2.site of a feature contains wrong plugin versions [message #545772 is a reply to message #545590] Thu, 08 July 2010 23:32 Go to previous messageGo to next message
I wonder if this has something to do wiht the org.junit issue..
Re: p2.site of a feature contains wrong plugin versions [message #545929 is a reply to message #545590] Fri, 09 July 2010 11:46 Go to previous message
I have similar problems that I think stem from the same root cause. I have features explicitly requesting particular versions of a bundle, but only the newest gets included in a repo built with site.p2.
Invoking a regular old feature export from the tooling works.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=319329
Previous Topic:No component named org.eclipse.equinox.launcher.motif.hpux.PA_RISC
Next Topic:How to deal with source features in rmap
Current Time: Wed Jul 23 11:38:43 EDT 2025
Powered by FUDForum. Page generated in 0.26874 seconds
