Home » Eclipse Projects » Eclipse Platform » Can't create an IFile within my plugin directory?
Can't create an IFile within my plugin directory? [message #545482] Wed, 07 July 2010 20:06 Go to next message
Here's my code (more or less), running in Eclipse 3.5.
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IPath pluginStatePath = MyPlugin.getDefault().getStateLocation();
IPath tempPath = pluginStatePath.append("tempFile" + count++ ).addFileExtension( someExtension );
IFile tempFile = root.getFile(tempPath);
tempFile.create(...);
Now, when you call getStateLocation(), Eclipse is kind enough to create the folder for you (with mkdirs()). It exists. I stepped through the code to create the folder, and watched it appear in my Explorer window (I'm using windows 7).
But when I try to call tempFile.create(...), it always throws a CoreException stating that the parent folder doesn't exist.
"But it's already there!" I cry, and go stepping through more eclipse code. I end up in Workspace.getResourceInfo(), where "tree.includes(path)" fails, aint never heard of no .metadata folder.
Peachy.
So how do I convince IWorkspace to create an IFile for me?
Or, stepping back for a moment, how do I create a temporary IFile that I can use to show in an editor?
(whoops! Earthquake! Many miles away, shook us for 30-60 seconds... nothing fell.)
Good ol SoCal.
Re: Can't create an IFile within my plugin directory? [message #545501 is a reply to message #545482] Thu, 08 July 2010 01:33 Go to previous messageGo to next message
> Peachy.
Why create an IFile and not a simple java.io.File?
Dani
> (whoops!
> http://earthquake.usgs.gov/earthquakes/recenteqsww/Quakes/ci 10736069.php#details
> Good ol SoCal.
Re: Can't create an IFile within my plugin directory? [message #545714 is a reply to message #545482] Thu, 08 July 2010 13:52 Go to previous messageGo to next message
Why an IFile?
I'm going to open it in an editor, and I'm not sure at the time which one will be used. I'm using a FileEditorInput which gets passed to IDE.getEditorDescriptor. I cast that descriptor to internal.EditorDescriptor (I know, I know), and I call it's createEdtior() from there. This creates whichever editor for my file (a .js in this particular case) Eclipse would normally create, one that I can use as a tab in my FormEditor-derived class.
That and one would think that myWorkspaceRoot.getFile(...).create(...) would work for some reasonable-seeming set of parameters, particularly on an IPath handed to me by an Eclipse call.
PS: Eclipse Dev Types: createEditor is really handy for building editors to be used in tabs. I'd like to see it moved to the public interface so I can get rid of this nagging "you're using an internal class" warning.
Hmm... perhaps a FileStoreEditorInput? I'm still pretty new to Eclipse plugin programming. To be honest, what I REALLY want is something like a ByteArrayEditorInput. Hopefully they added one in 3.6... I haven't had the chance to check yet...
Doesn't look that way.
Hmm... IStorage looks trivial to implement for a byte array. IStorageEditorInput.
Now we're talking... I don't see a way to write to an IStorage, so some editors might choke... one way to find out.
Re: Can't create an IFile within my plugin directory? [message #545781 is a reply to message #545714] Fri, 09 July 2010 02:36 Go to previous messageGo to next message
Mark Storer wrote:
> Why an IFile?
> class" warning.
Just use org.eclipse.ui.ide.IDE.openEditorOnFileStore(IWorkbenchPage,
IFileStore) where the file store points to the temp file.
Dani
Re: Can't create an IFile within my plugin directory? [message #545954 is a reply to message #545781] Fri, 09 July 2010 13:10 Go to previous messageGo to next message
Sadly, that won't work either. IDE.openEditor*'s all create and open a top-level editor.
I'm building a FormEditor-based editor, and want a JS editor within it (along with some custom form pages we've whipped up and an XML viewer) as a tab.
My addPage code looks like this:
            EditorDescriptor desc = (EditorDescriptor) IDE
                    .getEditorDescriptor("foo.js");
            if (desc != null) {
                jsEditor = desc.createEditor();
                addPage(SCRIPT_PAGE_IDX, jsEditor, jsInput);
            } // else log an error
EditorDescriptor is the internal class (yeah, yeah) that implements IEditorDescriptor. Using it lets me whip up the same editor (createEditor()) that IDE would have built for the same extension, only in a tab. And I have to use IEditorInput because that's all addPage will take.
In theory, if our users don't have the JSDT installed, the could end up with a regular text editor, which is fine with me. In practice, our plugin requires that the JSDT be installed.
(and what's the difference between theory and practice? In theory, there's no difference between theory and practice)
Re: Can't create an IFile within my plugin directory? [message #546037 is a reply to message #545954] Sat, 10 July 2010 03:59 Go to previous messageGo to next message
> a top-level editor.
By all means, then look at the code there to figure out how the file
from the OS is opened. It's really not that hard ;-)
Dani
> as a tab.
> if (desc != null) {
> addPage will take.
Re: Can't create an IFile within my plugin directory? [message #546457 is a reply to message #546037] Mon, 12 July 2010 17:08 Go to previous messageGo to next message
I think I figured out the problem.
This returns an ABSOLUTE path. Resource.getResourceInfo() is expecting to be a relative path at that point.
So it looks for "/Users/mark storer/workspace/.metadata" under the workspace folder, and fails just as you'd expect.
I fixed a similar problem moments ago thusly:
            IPath myPath = new Path(myPathStr);
            myPath= myPath.makeRelativeTo(ResourcesPlugin.getWorkspace().getRoot().getLocation());
Nope... Eclipse doesn't load a phony IProject for ".metadata"... at least not in 3.5. Odd, it does load a ".project" under each project. Humph.
Re: Can't create an IFile within my plugin directory? [message #547893 is a reply to message #546457] Tue, 20 July 2010 02:27 Go to previous messageGo to next message
"Mark Storer" <mstorer3772@gmail.com> wrote in message
news:i1g08n$nfs$1@build.eclipse.org...
> myPath=
> myPath.makeRelativeTo(ResourcesPlugin.getWorkspace().getRoot ().getLocation());
Not every file or directory is an IResource; only those that are contained
within projects. In particular, files within the plugins directory are not
IResources, they're just files.
..project is the name of the file (in each project) that stores the project
configuration. It's a text file; you can open it up if you view the project
in the Navigator view, which shows an unfiltered filesystem view of the
project.
Re: Can't create an IFile within my plugin directory? [message #548096 is a reply to message #547893] Tue, 20 July 2010 12:10 Go to previous message
My initial understanding was that IPath and IResource were interchangeable, which lead to my confusion... on account of them being interchangeable only some of the time.
Having progressed a bit further up the learning curve I now Get It that IPaths are paths that can be relative or absolute. IResources are a ResourcesPlugin thing, and thus part of the IDE which may not be available for some apps... whereas IPath is a RT/Core/whatever-it-is thing, and thus Always There. And while there are various mechanisms to go back and forth, IResources are always associated with projects, with the exception of the workspace, which is just there to hang projects off of.
So just a bit of confusion on my part. Still bugs me... but clearly not A Bug.
Previous Topic:core tools does not work with eclipse 3.6
Next Topic:Where do all those "trace" check boxes come from when debugging a plugin?
Current Time: Wed Jul 23 04:18:09 EDT 2025
Powered by FUDForum. Page generated in 0.06297 seconds
