Home » Eclipse Projects » Eclipse Platform » Any way to know when bundles are started?
Any way to know when bundles are started? [message #543863] Wed, 30 June 2010 17:31 Go to next message
My bundle activator schedules a background job for 5 seconds in the future. The job should only run after "startup" has completed, and since this is a server, all bundles are activated at startup.
Instead of waiting 5 seconds, how can I wait for "startup" (StartLevelManager#resumeBundles) to complete? Do I use EventHook, or the EventDispatcher service?
Re: Any way to know when bundles are started? [message #544854 is a reply to message #543863] Mon, 05 July 2010 13:36 Go to previous messageGo to next message
You can try listening for FrameworkEvent.STARTED :
* This event is fired when the Framework has started after all installed
* bundles that are marked to be started have been started and the Framework
* has reached the initial start level. The source of this event is the
* System Bundle.
These events are delivered asynchronously to FrameworkListener's registered
on BundleContext.addFrameworkListener
-Andrew
Re: Any way to know when bundles are started? [message #545183 is a reply to message #544854] Tue, 06 July 2010 21:36 Go to previous messageGo to next message
Thanks! And one last thing. If I'm not adding the listener directly in my Activator's start(BundleContext context), then it's possible that this event has already come and gone. So is there a "pull" mechanism to query whether or not the "framework" has already published the "STARTED" event?
Re: Any way to know when bundles are started? [message #545430 is a reply to message #545183] Wed, 07 July 2010 13:45 Go to previous messageGo to next message
You can probably check StartLevel#getStartLevel() and compare it to
BundleContext.getProperty("osgi.startLevel")
Re: Any way to know when bundles are started? [message #545496 is a reply to message #545430] Thu, 08 July 2010 00:22 Go to previous message
Andrew Niefer wrote on Wed, 07 July 2010 13:45
When my bundle is starting,
getStartLevel() returns 4,
context.getProperty("osgi.bundles.defaultStartLevel") returns 4 too.
But, when the event type STARTED is fired, getStartLevel() returns 6, (as set by EclipseStarter). It seems like getStartLevel() returns the current level obtained, not the target level. "osgi.startLevel" is on FrameworkProperties, but that's an eclipse internal class.
Previous Topic:My editor is filtered out during junit test, any ideas why?
Next Topic:Include one directory from one java project into current project
Current Time: Sat Jul 26 11:31:52 EDT 2025
Powered by FUDForum. Page generated in 0.09423 seconds
