Home » Archived » Buckminster » "Unable to acquire application service" on Mac OS X
Re: "Unable to acquire application service" on Mac OS X [message #545181 is a reply to message #540557] Tue, 06 July 2010 20:31 Go to previous message
Scott,
I just tried this and was able to resolve. Make sure that you delete the buckminster directory before attempting to do this. Also, don't make my initial mistake -- the p2 arguments go on the original director call, not the install -- buckminster won't complain about those because it fails with the first issue before it gets there.
Scott Anderson wrote on Wed, 16 June 2010 10:14
I'm experiencing this as well using buckminster headless 3.6...
Here is error log
!SESSION 2010-06-16 10:10:09.857 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: import -Dxxx.home=/Volumes/Secure/src/xxx /Volumes/Secure/src/xxx/projects/xxxx.site/site.cquery
Command-line arguments: -data /Volumes/Secure/src/xxx/dist/workspace import -Dxx=/Volumes/Secure/src/xx /Volumes/Secure/src/xx/projects/xxx.site/site.cquery
!ENTRY org.eclipse.osgi 4 0 2010-06-16 10:10:10.622
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:How to best deal with broken Maven2 meta-data
Next Topic:Can't install headless 3.6
Current Time: Tue Jun 17 03:57:01 EDT 2025
Powered by FUDForum. Page generated in 0.02859 seconds
