Home » Archived » Buckminster » "Unable to acquire application service" on Mac OS X
"Unable to acquire application service" on Mac OS X [message #517230] Fri, 26 February 2010 11:10 Go to next message
I just ran into a little problem when running Buckminster on Mac OS X,
just thought I should post a note about it in case somebody else runs
into this.
When starting Buckminster it failed with this exception in the log:
!SESSION 2010-02-26 16:59:50.552
eclipse.buildId=unknown
java.version=1.6.0_15
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=carbon, NL=de_DE
Framework arguments: help
Command-line arguments: help
!ENTRY org.eclipse.osgi 4 0 2010-02-26 16:59:52.200
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
at
at
java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
I guess the problem is the combination ARCH=x86_64, WS=carbon which was
guessed automatically, when I explicitly specified these when
installing Buckminster this fixed the problem:
../director -r
http://download.eclipse.org/tools/buckminster/headless-3.5/ -d
/Users/ralf/jobs/re_builds/buckminster35/ -p Buckminster -i
org.eclipse.buckminster.cmdline.product -p2.os macosx -p2.ws cocoa
-p2.arch x86_64 -p2.nl en
Greetings,
Ralf
http://www.ralfebert.de/blog/
Re: "Unable to acquire application service" on Mac OS X [message #517243 is a reply to message #517230] Fri, 26 February 2010 11:20 Go to previous messageGo to next message
Hi Ralf,
Thanks for sharing this info. It should go into the "troubleshooting" section of our docs. I've seen other types of
strange guesses before (motif instead of swt typically).
- thomas
On 02/26/2010 05:10 PM, Ralf Ebert wrote:
> into this.
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> at
> at
> guessed automatically, when I explicitly specified these when installing
> ../director -r
> Greetings,
> Ralf
Re: "Unable to acquire application service" on Mac OS X [message #535846 is a reply to message #517230] Tue, 25 May 2010 21:02 Go to previous messageGo to next message
HI,i had this problem too. here is my log.
!SESSION 2010-05-25 13:41:35.043 -----------------------------------------------
java.version=1.6.0_17
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/zhoutao/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch x86 -keyring /Users/zhoutao/.eclipse_keyring -showlocation
!ENTRY org.eclipse.osgi 4 0 2010-05-25 13:41:36.180
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
but i didn't know how to fix it , and i didn't understand this
../director -r
can you tell me how to do this ? thanks.
Email:zt2620zt@qq.com
Re: "Unable to acquire application service" on Mac OS X [message #538024 is a reply to message #535846] Fri, 04 June 2010 10:31 Go to previous messageGo to next message
QuadBox:director maarten$ ./director -r http://download.eclipse.org/tools/buckminster/headless-3.5/ -p Buckminster -i org.eclipse.buckminster.cmdline.product -d /Library/Java/Development/buckminster/ -p2.os macosx -p2.ws cocoa -p2.arch x86_64 -p2.nl en
Installing org.eclipse.buckminster.cmdline.product 1.1.350.r11146.
Operation completed in 3798 ms.
So far it works
QuadBox:buckminster maarten$ ./buckminster install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!SESSION 2010-06-04 16:23:14.266 -----------------------------------------------
java.version=1.6.0_20
BootLoader constants: OS=macosx, ARCH=x86_64, WS=carbon, NL=nl_NL
Framework arguments: install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature
Command-line arguments: install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-06-04 16:23:15.191
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
QuadBox:buckminster maarten$ ./buckminster -application org.eclipse.buckminster.cmdline.product install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!SESSION 2010-06-04 16:27:11.293 -----------------------------------------------
Framework arguments: -application org.eclipse.buckminster.cmdline.product install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature
Command-line arguments: -application org.eclipse.buckminster.cmdline.product install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-06-04 16:27:12.324
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.buckminster.cmdline.product" could not be found in the registry. The applications available are: org.eclipse.buckminster.cmdline.headless, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.artifact.repository.mirrorApplication , org.eclipse.equinox.p2.director.app.application, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.metadata.repository.mirrorApplication , org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher , org.eclipse.ant.core.antRunner, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build, org.eclipse.buckminster.aggregator.
QuadBox:buckminster maarten$ ./buckminster -application org.eclipse.buckminster.cmdline.headless install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
!SESSION 2010-06-04 16:27:36.687 -----------------------------------------------
Framework arguments: -application org.eclipse.buckminster.cmdline.headless install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature
Command-line arguments: -application org.eclipse.buckminster.cmdline.headless install http://download.eclipse.org/tools/buckminster/headless-3.5/ org.eclipse.buckminster.aggregator.engine.feature -consoleLog
Somehow the default application is not copied into the executable or some ini file, but I'm to much of a p2/osgi newbie to resolve this.
Re: "Unable to acquire application service" on Mac OS X [message #540557 is a reply to message #517230] Wed, 16 June 2010 10:14 Go to previous messageGo to next message
I'm experiencing this as well using buckminster headless 3.6...
Here is error log
!SESSION 2010-06-16 10:10:09.857 -----------------------------------------------
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: import -Dxxx.home=/Volumes/Secure/src/xxx /Volumes/Secure/src/xxx/projects/xxxx.site/site.cquery
Command-line arguments: -data /Volumes/Secure/src/xxx/dist/workspace import -Dxx=/Volumes/Secure/src/xx /Volumes/Secure/src/xx/projects/xxx.site/site.cquery
!ENTRY org.eclipse.osgi 4 0 2010-06-16 10:10:10.622
!STACK 1
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: "Unable to acquire application service" on Mac OS X [message #545181 is a reply to message #540557] Tue, 06 July 2010 20:31 Go to previous message
Scott,
I just tried this and was able to resolve. Make sure that you delete the buckminster directory before attempting to do this. Also, don't make my initial mistake -- the p2 arguments go on the original director call, not the install -- buckminster won't complain about those because it fails with the first issue before it gets there.
Scott Anderson wrote on Wed, 16 June 2010 10:14
Here is error log
!STACK 1
Previous Topic:How to best deal with broken Maven2 meta-data
Next Topic:Can't install headless 3.6
Current Time: Sat Jul 26 07:52:29 EDT 2025
Powered by FUDForum. Page generated in 0.05248 seconds
