Buckminster 3.6: URI is not hierarchical [message #545023] |
Tue, 06 July 2010 08:43  |
I am getting the following error when using buckminster 3.6 in hudson... If I switch back to 3.5 this will not happen.
Note: that error message comes when the rcp is being packaged (create.product is being called)....
!ENTRY org.eclipse.equinox.p2.engine 4 1002 2010-07-06 13:51:00.371
!MESSAGE URI is not hierarchical
!STACK 0
java.lang.IllegalArgumentException: URI is not hierarchical
at java.io.File.<init>(File.java:335)
at org.eclipse.equinox.internal.p2.engine.ProfileMetadataReposi tory.getProfile(ProfileMetadataRepository.java:174)
at org.eclipse.equinox.internal.p2.engine.ProfileMetadataReposi tory. <init>(ProfileMetadataRepository.java:49)
at org.eclipse.equinox.internal.p2.engine.ProfileMetadataReposi toryFactory.load(ProfileMetadataRepositoryFactory.java:36)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:747)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:652)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:96)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplica tion.initializeRepositories(DirectorApplication.java:407)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplica tion.run(DirectorApplication.java:796)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplica tion.start(DirectorApplication.java:954)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
!ENTRY org.eclipse.equinox.p2.core 4 0 2010-07-06 13:51:00.387
!MESSAGE Unable to load repositories.
FUDForum. Page generated in 0.05339 seconds
