Home » Modeling » Epsilon » [eol] problem with creating a native java String
[eol] problem with creating a native java String [message #545037] Tue, 06 July 2010 09:44 Go to next message
hi all
i was trying to create a java.lang.String as native type in eol (as shown in the book, listing 3.8 ), but it does not seem to work. i tried things like the following, but it always tells me that the methods (replaceAll, indexOf etc.) are not found.
var code = new Native("java.lang.String");
code.replaceAll("", node.viewmap.classBody.toString());
var index = code.indexOf("createContents()");
has anyone an idea what i'm doing wrong?
thanks
marco
Re: [eol] problem with creating a native java String [message #545062 is a reply to message #545037] Tue, 06 July 2010 10:36 Go to previous messageGo to next message
Hi Marco,
In the current version of Epsilon all instances of java.lang.String are
wrapped as instances of EolString. However, we've now removed all
wrapping and will be releasing a new interim version shortly (within the
next couple of hours) in which you can call all native functions as
well. I'll let you know when it's ready.
Dimitris
mkranz wrote:
> hi all
> thanks
> marco
Re: [eol] problem with creating a native java String [message #545079 is a reply to message #545062] Tue, 06 July 2010 10:58 Go to previous messageGo to next message
hello dimitris
sounds great! but i still have to use a native java string, right?
oh and btw., how's assignment handled with native strings?
can i do this?
var string = new Native("java.lang.String");
string = "bla";
cheers
marco
Re: [eol] problem with creating a native java String [message #545097 is a reply to message #545079] Tue, 06 July 2010 11:35 Go to previous messageGo to next message
Hi Marco,
In the new version you won't have to use Native(...) to define a native
String as all strings will be native. var a : String; will create a new
native string and then you can perform the assignment using = (i.e. a =
"bla";).
Dimitris
mkranz wrote:
> hello dimitris
> can i do this?
> string = "bla";
> cheers
> marco
Re: [eol] problem with creating a native java String [message #545105 is a reply to message #545097] Tue, 06 July 2010 12:04 Go to previous message
Hi Marco,
The new version is now available in the interim update site:
http://download.eclipse.org/modeling/gmt/epsilon/interim/
Please note that we have heavily refactored some of the core parts of
Epsilon in this version and although all our tests are green, new bugs
may still have found their way in, so I'd recommend trying this in a new
Eclipse instance - just in case.
Dimitris
Dimitris Kolovos wrote:
> Hi Marco,
> "bla";).
> Cheers,
> Dimitris
> mkranz wrote:
>> hello dimitris
>> can i do this?
>> string = "bla";
>> cheers
>> marco
Re: [eol] problem with creating a native java String [message #590471 is a reply to message #545037] Tue, 06 July 2010 10:36 Go to previous message
Hi Marco,
Dimitris
mkranz wrote:
> hi all
> thanks
> marco
Re: [eol] problem with creating a native java String [message #590482 is a reply to message #545062] Tue, 06 July 2010 10:58 Go to previous message
hello dimitris
can i do this?
string = "bla";
cheers
marco
Re: [eol] problem with creating a native java String [message #590491 is a reply to message #545079] Tue, 06 July 2010 11:35 Go to previous message
Hi Marco,
"bla";).
Dimitris
mkranz wrote:
> hello dimitris
> can i do this?
> string = "bla";
> cheers
> marco
Re: [eol] problem with creating a native java String [message #590501 is a reply to message #545097] Tue, 06 July 2010 12:04 Go to previous message
Hi Marco,
Dimitris
> Hi Marco,
> "bla";).
> Cheers,
> Dimitris
> mkranz wrote:
>> hello dimitris
>> can i do this?
>> string = "bla";
>> cheers
>> marco
Previous Topic:[eol] problem with creating a native java String
Next Topic:Accessing MapInfo structure from ECL
Current Time: Wed Jul 23 06:49:31 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
