Home » Eclipse Projects » Eclipse Platform » "org.junit4" in target platform?
"org.junit4" in target platform? [message #544973] Tue, 06 July 2010 04:58 Go to next message
I would like to use a smaller target platform than the default running
with its many plugins.
I created a .target file and added some features from the helios update
site (Equinox Core SDK, ...)
Every works fine except "org.junit4". I can't find a single feature,
which installs a working "org.junit4" bundle. There are some containing
org.junit (without "4" at the end), but I need the other one.
Could someone please tell me, how I can get this bundle into my target
platform?
Lars
Re: "org.junit4" in target platform? [message #545115 is a reply to message #544973] Tue, 06 July 2010 12:35 Go to previous messageGo to next message
The org.junit4 bundle was a non-sense that was removed from Helios (replaced by org.junit -without 4, but with a good version). You can learn more on this topic here: http://wiki.eclipse.org/Eclipse/Testing/JUnit4_Changes
What we were do here to get bundles depending on org.junit4 (such as SWTBot), it to checkout and use the "alias" version of org.junit4, that you can find here: plugin@org.junit4 =v20100104,:pserver:anonymous:@dev.eclipse.org:/cvsroot/ecli pse,,org.junit4
HTH
Le 06/07/2010 10:58, Lars Fischer a écrit :
> Hello,
> platform?
> Regards,
> Lars
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: "org.junit4" in target platform? [message #545525 is a reply to message #545115] Thu, 08 July 2010 03:36 Go to previous messageGo to next message
Hello Mickael,
> you can find here:
Thank you for this information.
But there is no single feature in the helios p2 repository to add only
junit to a target platform?
Lars
Re: "org.junit4" in target platform? [message #545559 is a reply to message #545525] Thu, 08 July 2010 04:33 Go to previous messageGo to next message
There is no way to install only org.junit from Helios repo to target platform using the UI. However, you can perform this operation with command line using p2 director. See http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/p2_director.html
Re: "org.junit4" in target platform? [message #545838 is a reply to message #545559] Fri, 09 July 2010 07:02 Go to previous message
Thank you for this hint!
Lars
Previous Topic:Eclipse Job framework: FIFO queue that respects priority?
Next Topic:Temporary Files & Editors
Current Time: Wed Jul 23 23:27:27 EDT 2025
Powered by FUDForum. Page generated in 0.04205 seconds
