Home » Archived » M2M (model-to-model transformation) » [QVTo] Import from plug-ins?
[QVTo] Import from plug-ins? [message #543672] Wed, 30 June 2010 04:35 Go to next message
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Imports from other projects, or even better, from plug-ins, doesn't seem
to work in QVTo:
import
platform:/plugin/nl.tue.cif.v2x1x1.cifcopy.qvto/transforms/cifcopy.qvto;
import platform:/plugin/nl.tue.cif.v2x1x1.cifcopy.qvto/transforms/cifcopy;
import nl.tue.cif.v2x1x1.cifcopy.qvto.transforms.cifcopy;
import nl.tue.cif.v2x1x1.cifcopy.qvto.cifcopy;
import cifcopy;
None of this works, even though I have a
nl.tue.cif.v2x1x1.cifcopy.qvto_1.0.0.jar in the Eclipse 'plugins'
directory, and it contains a 'transforms' directory with a
'cifcopy.qvto' transformation.
Does anyone know whether it is possible to import from plug-ins?
Dennis
Re: [QVTo] Import from plug-ins? [message #544894 is a reply to message #543672] Mon, 05 July 2010 18:20 Go to previous messageGo to next message
Hi Dennis ,
In order to import QVTo script from plug-in you should declare script
export in plugin.xml like follows:
<extension
point="org.eclipse.m2m.qvt.oml.runtime.qvtTransformation">
<transformation
file="transforms/cifcopy.qvto"
id="transforms.cifcopy">
</transformation>
</extension>
Then import statement in QVTo script should work:
import transforms.cifcopy;
Note that 'id' field should correspond to directory structure where
script is placed.
Sergey
Dennis Hendriks wrote:
> Hello,
> to work in QVTo:
> import
> import cifcopy;
> Dennis
Re: [QVTo] Import from plug-ins? [message #545026 is a reply to message #544894] Tue, 06 July 2010 08:52 Go to previous messageGo to next message
Hello Sergey,
thanks a lot for your reply. I tried adding the extension to the
plugin.xml, adding org.eclipse.m2m.qvt.oml.runtime as plugin to the
'required plug-ins' of the project, and I exported the project. I
restarted Eclipse. However, I still get an 'Cannot find imported
compilation unit 'transforms.cifcopy'' error.
Any idea what can be wrong?
Best,
Dennis
Sergey Boyko wrote:
> Hi Dennis ,
> <extension
> <transformation
> </transformation>
> </extension>
> script is placed.
> Regards,
> Sergey
>> Hello,
>> seem to work in QVTo:
>> import
>> import
>> import cifcopy;
>> Dennis
Re: [QVTo] Import from plug-ins? [message #545099 is a reply to message #545026] Tue, 06 July 2010 11:33 Go to previous messageGo to next message
Hi Dennis ,
I have no idea what's wrong. In QVTo test suit we have distinct test
case for that.
Might it be that your plug-in was not accepted by platform after restart?
You can try to launch new Eclipse instance right from your working
instance (new Eclipse Application launch configuration). That is how is
just checked that the solution works.
Sergey
> Hello Sergey,
> Best,
> Dennis
> Sergey Boyko wrote:
>> Hi Dennis ,
>> <extension
>> <transformation
>> </transformation>
>> </extension>
>> script is placed.
>> Regards,
>> Sergey
>>> Hello,
>>> import
>>> import
>>> import cifcopy;
>>> Dennis
Re: [QVTo] Import from plug-ins? [message #545198 is a reply to message #545099] Wed, 07 July 2010 02:41 Go to previous message
Hello Sergey,
I removed the plug-in, restarted Eclipse, then created a launch
configuration for a new Eclipse Application, and executed it. In this
Eclipse, it worked. I closed it, re-exported the plug-in in the 'normal'
Eclipse, and restarted Eclipse. It still did not work here. However,
when I closed the project containing the imported transformation,
suddenly it did work. Opening the project in the workspace after that
didn't matter, it still worked.
Is it a known problem that imports from exported QVTo transformations
don't work if the source project of the exported plug-in is in the
workspace?
Another issue: In the one QVTo project I have a transforms directory
with cifcopy.qvto, and cifwalk.qvto. I exported them like this:
    <extension
       <transformation
       </transformation>
    </extension>
    <extension
       <transformation
             file="transforms/cifwalk.qvto"
             id="nl.tue.cif.v2x1x1.cifcopy.qvto">
       </transformation>
    </extension>
The second one (cifwalk) is illegal, from what you stated before (as the
file and id don't match). I could import transforms.cifcopy, but not
nl.tue.cif.v2x1x1.cifcopy.qvto, which supports your claim. However, I
could also import transforms.cifwalk! This seemed very weird to me, as I
never exported it using that name. Any clue what is happening here?
Best,
Dennis
Sergey Boyko wrote:
> Hi Dennis ,
> case for that.
> Regards,
> Sergey
>> Hello Sergey,
>> Best,
>> Dennis
>> Sergey Boyko wrote:
>>> Hi Dennis ,
>>> <extension
>>> <transformation
>>> </transformation>
>>> </extension>
>>> script is placed.
>>> Regards,
>>> Sergey
>>>> Hello,
>>>> import
>>>> import
>>>> import cifcopy;
>>>> Dennis
Previous Topic:Ant import on buildfile with macros for javac
Next Topic:Re: [m2m-dev] [ATL] Does ATL support traceability?
Current Time: Sat Jul 19 02:43:07 EDT 2025
Powered by FUDForum. Page generated in 0.04991 seconds
