Home » Eclipse Projects » Eclipse 4 » SimpleIDE example: problem with selection
SimpleIDE example: problem with selection [message #544873] Mon, 05 July 2010 15:08 Go to next message
Hi all
i am trying a little bit with the e4 example SimpleIDE. I can select
different resources in the navigator without any problem. Then i open the
Context Menu View and select one of the items there. If i now try to select
a resource in the navigator i get the following exception:
java.lang.IllegalArgumentException: Variable selection is not modifiable in
the context PerspectiveImpl (simpleide.perspective.default) Context
at
org.eclipse.e4.core.internal.contexts.EclipseContext.interna lModify(EclipseContext.java:367)
at
org.eclipse.e4.core.internal.contexts.EclipseContext.interna lModify(EclipseContext.java:377)
at
org.eclipse.e4.core.internal.contexts.EclipseContext.modify( EclipseContext.java:357)
at
org.eclipse.e4.demo.simpleide.navigator.internal.ResourceNav igator$2.selectionChanged(ResourceNavigator.java:132)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.jface.util.SafeRunnable$1.run(SafeRunnable.java: 128)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2162)
at
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1190)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1220)
at
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:389)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine $4.run(PartRenderingEngine.java:664)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine .run(PartRenderingEngine.java:589)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRu nUI(E4Workbench.java:103)
at
org.eclipse.e4.ui.internal.workbench.swt.E4Application.start (E4Application.java:124)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
The problem seams to be in the method SelectionServiceImpl.setSelection:
serviceRoot.getContext().set(IServiceConstants.ACTIVE_SELECT ION,
selection);
What is the difference between using
"context.modify(IServiceConstants.ACTIVE_SELECTION, ...)" and
"setSelection(selection)" on the ESelectionService instance?
Thanks for information
Re: SimpleIDE example: problem with selection [message #544889 is a reply to message #544873] Mon, 05 July 2010 17:52 Go to previous messageGo to next message
This looks like something is messing up the IEclipseContext. The
difference between:
IEclipseContext#set() and IEclipseContext#modify() is that the selection
information is stored in the WindowContext. With modify we are search up
the hierarchy until we find the variable-name. IEclipseContext#set()
only sets the value in the current context and doesn't search up in the
hierarchy.
It looks like something is declaring an variable named "selection" in
the perspective context!
Tom
Am 05.07.10 21:08, schrieb Reto Urfer:
> Hi all
> the Context Menu View and select one of the items there. If i now try to
> select a resource in the navigator i get the following exception:
> in the context PerspectiveImpl (simpleide.perspective.default) Context
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> selection);
Re: SimpleIDE example: problem with selection [message #544895 is a reply to message #544889] Mon, 05 July 2010 18:11 Go to previous message
It looks like the code in SimpleIDE was not following the best practice
that has been defined through ESelectionService (it was using an old
technic to propagate the selection)
I've fixed the problem now.
Tom
Am 05.07.10 23:52, schrieb Tom Schindl:
> difference between:
> hierarchy.
> Tom
>> Hi all
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> selection);
Re: SimpleIDE example: problem with selection [message #578563 is a reply to message #544873] Mon, 05 July 2010 17:52 Go to previous message
difference between:
hierarchy.
Tom
> Hi all
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> selection);
Re: SimpleIDE example: problem with selection [message #578588 is a reply to message #544889] Mon, 05 July 2010 18:11 Go to previous message
Tom
> difference between:
> hierarchy.
> Tom
>> Hi all
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> selection);
Previous Topic:SimpleIDE example: problem with selection
Next Topic:Dependency Injection: clarification needed
Current Time: Wed Jul 23 05:23:25 EDT 2025
Powered by FUDForum. Page generated in 0.08341 seconds
