Home » Eclipse Projects » Nebula » Sorting in TableCombo
Sorting in TableCombo [message #544712] Mon, 05 July 2010 01:02 Go to next message
In my application I m using tablecombo with 2 columns. I have added sorter
to both the columns. This works fine when no combo item is selected.
Clicking the column header in combo sorts the list and the combo remains
open after sorting is done.
But if a item is selected in the combo, clicking the combo header sorts the
list but the combo is closed and combo text is set to the selected item.
What I need is the the combo remains expanded after sorting.
I have added a selection listner to the colums in table combo for sorting
and another selection listner to TableComboViewer.
Is there a way to do so ?
Please do let me know
Thanks in Advance!
Neha
Re: Sorting in TableCombo [message #544755 is a reply to message #544712] Mon, 05 July 2010 08:36 Go to previous messageGo to next message
Neha,
Do you have a snippet that shows the issue that you are seeing? If so, attach it and I will look into the issue.
Marty
Re: Sorting in TableCombo [message #544934 is a reply to message #544755] Tue, 06 July 2010 03:05 Go to previous messageGo to next message
Hi Marty,
Below is the code snippet. Please do have a look and let me know if anything
can be done
comboRecordViewer.getTableCombo().defineColumns(
new String[] { "ID", "Name" });
combo= comboViewer.getTableCombo();
for (iCounter = 0; iCounter < 2; iCounter++) {
ColumnSelectionListener colListener = new ColumnSelectionListener(
iCounter);
combo.getTable().getColumn(iCounter)
..addSelectionListener(colListener);
// ColumnSelectionLlistner code is below
private class ColumnSelectionListener extends SelectionAdapter {
private int colNumber;
private ColumnSelectionListener(int colNumber) {
this.colNumber = colNumber;
public void widgetSelected(SelectionEvent e) {
TableColumn sortColumn = combogetTable()
..getSortColumn();
TableColumn currentColumn = (TableColumn) e.widget;
int dir = combo.getTable().getSortDirection();
if (sortColumn == currentColumn) {
dir = dir == SWT.UP ? SWT.DOWN : SWT.UP;
} else {
combo.getTable().setSortColumn(currentColumn);
// sorting direction is descending as its already sorted in
// ascending order.
if (currentColumn == combo.getTable().getColumn(
colNumber)) {
dir = SWT.DOWN;
} else {
dir = SWT.UP;
combo.getTable().setSortDirection(dir);
comboViewer.setSorter(new TableSorter(
colNumber, dir));
"TableSorter" is a class that extends ViewerSorter class and has sorting
logic.
Thanks & Regards
Neha.
"Marty Jones" <martybjones@gmail.com> wrote in message
news:i0sjk8$lgo$1@build.eclipse.org...
> Neha,
> Marty
Re: Sorting in TableCombo [message #544937 is a reply to message #544934] Tue, 06 July 2010 03:11 Go to previous messageGo to next message
Hi Neha,
Though I can't speak for Marty. It would help Marty if he gets a fully
runnable snippet without having to code something his own.
I'd use one of the snippets available and modify it so that we can
reproduce it without any time overhead on ourside.
Tom
Am 06.07.10 09:05, schrieb Neha:
> Hi Marty,
> can be done
> iCounter);
> @Override
> .getSortColumn();
> } else {
> // ascending order.
> colNumber)) {
> dir = SWT.DOWN;
> } else {
> dir = SWT.UP;
> colNumber, dir));
> logic.
> Thanks & Regards
> Neha.
>> Neha,
>> Thanks,
>> Marty
Re: Sorting in TableCombo [message #545014 is a reply to message #544937] Tue, 06 July 2010 07:43 Go to previous messageGo to next message
Neha,
Tom is correct. It is always helpful to have a full snippet showing the issue that you are seeing. That way I will see exactly what you are seeing instead of me coding a full snippet and may not be able to reproduce the bug.
Marty
Re: Sorting in TableCombo [message #599844 is a reply to message #544712] Mon, 05 July 2010 08:36 Go to previous messageGo to next message
Neha,
Marty
Re: Sorting in TableCombo [message #599861 is a reply to message #599844] Tue, 06 July 2010 03:05 Go to previous messageGo to next message
Hi Marty,
can be done
iCounter);
..getSortColumn();
} else {
// ascending order.
colNumber)) {
dir = SWT.DOWN;
} else {
dir = SWT.UP;
colNumber, dir));
logic.
Thanks & Regards
Neha.
> Neha,
> Marty
Re: Sorting in TableCombo [message #599868 is a reply to message #544934] Tue, 06 July 2010 03:11 Go to previous messageGo to next message
Hi Neha,
Tom
> Hi Marty,
> can be done
> iCounter);
> @Override
> .getSortColumn();
> } else {
> // ascending order.
> colNumber)) {
> dir = SWT.DOWN;
> } else {
> dir = SWT.UP;
> colNumber, dir));
> logic.
> Thanks & Regards
> Neha.
>> Neha,
>> Thanks,
>> Marty
Re: Sorting in TableCombo [message #599872 is a reply to message #544937] Tue, 06 July 2010 07:43 Go to previous message
Neha,
Marty
Previous Topic:[paperclips] Printing error when there are some kind of images
Next Topic:One Framework to bind them All ?!
Current Time: Wed Jul 30 15:00:10 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
