Home » Language IDEs » ServerTools (WTP) » Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits
Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #544446] Fri, 02 July 2010 13:15 Go to next message
On Ubuntu 10.04 desktop 64 bits:
On a fresh package of Eclipse Helios CDT from eclipse.org, with ~/.eclipse deleted, I installed the plugin "Eclipse XML Editors and Tools" which I used in the past on erlier version of Eclipse and Ubuntu. However, it doesn't seem to recognize XML files... Eclipse still see them as regular text files and I can't find a way to make it see them or open them as XML files, with the internal XML editor.
That being said, I tried the exact same thing, but on WinXP Pro 32 bits and it worked without problem.
Your help is much appreciated.
Re: Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #544459 is a reply to message #544446] Fri, 02 July 2010 14:02 Go to previous messageGo to next message
Files opened previously will open with the last editor you used on them,
unless you choose "Open with" from the file's context menu. If the
editor is not available from that menu, are the preferences for it
showing up?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #544471 is a reply to message #544459] Fri, 02 July 2010 14:58 Go to previous messageGo to next message
Here are useful information:
http://www.spoluck.ca/files/1.JPG
When I right click on a XML file:
http://www.spoluck.ca/files/2.JPG
When I choose other in the contextual menu of the XML file:
http://www.spoluck.ca/files/3.JPG
I don't see any preference for the plugin anywhere I look.
Re: Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #545067 is a reply to message #544471] Tue, 06 July 2010 10:30 Go to previous messageGo to next message
The contents of your log files may hold some information about why the
XML plug-ins aren't loading. Otherwise I'm not sure how to proceed.
http://wiki.eclipse.org/IRC_FAQ#Where_are_Eclipse.27s_log_fi les_located.3F
Nitin Dahyabhai
IBM Rational
Re: Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #659722 is a reply to message #545067] Tue, 15 March 2011 07:00 Go to previous messageGo to next message
I realize it's been about 2 years since this thread, but I'm having identical problems while using Windows XP SP 3.0.
Re: Can't use Eclipse XML Editors and Tools in Helios on Ubuntu 10.04 64 bits [message #659745 is a reply to message #659722] Tue, 15 March 2011 09:15 Go to previous message
Hi Matt,
My problem went away a few months ago, when I installed the very latest version of Eclipse Helios. What version are you currently using? You also have to make sure the repository URL is appropriate for the version of Eclipse you use.
I think I am using http://download.eclipse.org/releases/helios/ for my Helios install.
Previous Topic:JSP call the axis2 code generator
Next Topic:web resources in project explorer
Current Time: Sun Jul 20 21:05:28 EDT 2025
Powered by FUDForum. Page generated in 0.47991 seconds
