cant create a new connection [message #544420] |
Fri, 02 July 2010 11:42  |
I've freshly installed Eclipse Helios - PHP, and installed everything related to RSE to try to fix this.
Trying to create a new Linux connection, I enter the address of the host, and I click Finish, I immediately get RSEG1003U - "An unexpected exception has occured."
Setup:
Windows 7 x64
Eclipse x64
Java x64
I also get the same error with 32-bit Eclipse and Java builds. I installed x64 versions to see if error would go away, but nope.
Below are the contents of the "Details" for this error.
at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.createNode(RSEDOMExporter.java:383)
at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.createNode(RSEDOMExporter.java:348)
at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.populateRSEDOM(RSEDOMExporter.java:142)
at org.eclipse.rse.internal.persistence.dom.RSEDOMExporter.createRSEDOM(RSEDOMExporter.java:92)
at org.eclipse.rse.internal.persistence.RSEPersistenceManager.save(RSEPersistenceManager.java:555)
at org.eclipse.rse.internal.persistence.RSEPersistenceManager.commitProfile(RSEPersistenceManager.java:257)
at org.eclipse.rse.internal.core.model.SystemProfileManager.commitSystemProfile(SystemProfileManager.java:117)
at org.eclipse.rse.internal.core.model.SystemProfile.commit(SystemProfile.java:272)
at org.eclipse.rse.internal.core.model.SystemProfileManager.commitProfiles(SystemProfileManager.java:108)
at org.eclipse.rse.internal.core.model.SystemProfileManager.runOperation(SystemProfileManager.java:99)
at org.eclipse.rse.internal.core.model.SystemProfileManager.run(SystemProfileManager.java:86)
at org.eclipse.rse.internal.core.model.SystemRegistry.createHost(SystemRegistry.java:1629)
at org.eclipse.rse.internal.core.model.SystemRegistry.createHost(SystemRegistry.java:1529)
at org.eclipse.rse.ui.wizards.newconnection.RSEDefaultNewConnectionWizard.performFinish(RSEDefaultNewConnectionWizard.java:388)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
FUDForum. Page generated in 0.34473 seconds
