Home » Eclipse Projects » Rich Client Platform (RCP) » DragAndDrop in AbstractDecoratedTextEditor
DragAndDrop in AbstractDecoratedTextEditor [message #544333] |
Fri, 02 July 2010 07:04  |
What is needed to enable D&D in a custom editor?
I currently do nothing specific and the drag operation seems to work
out-of-the-box... almost :(
When I drag the selected text cursor changes shape and the drop-position
indicator (thick vertical beam) loosely follows it.
Problem is when I drop it nothing happens (and sometimes I have a
leftover insertion point marker), so I think I didn't do some required
initialization.
Before You ask: Yes, PREFERENCE_TEXT_DRAG_AND_DROP_ENABLED is set to true.
I also saw "protected void initializeDragAndDrop(ISourceViewer viewer)",
but I don't know how to use it. Searches didn't turn up anything usable.
Can someone help me, pretty please?
Thanks in Advance
Mauro
Re: DragAndDrop in AbstractDecoratedTextEditor [message #545581 is a reply to message #545509] |
Thu, 08 July 2010 06:19   |
On 08/07/2010 8.19, Daniel Megert wrote:
> Mauro Condarelli wrote:
>>>> Hi,
>>>> drop-position indicator (thick vertical beam) loosely follows it.
>>>> initialization.
>>>> true.
>>>> viewer)", but I don't know how to use it. Searches didn't turn up
>>>> anything usable.
>>> It should work out of the box (see e.g. Java editor or source pages in
>>> PDE editors). No idea what your editor tweaks to break this.
>>> Dani
>>>> Thanks in Advance
>>>> Mauro
>> Thanks Daniel,
>> any suggestion where to put a breakpoint to debug this?
> Inside
> org.eclipse.ui.texteditor.AbstractTextEditor.installTextDrag AndDrop(ISourceViewer).
> My guess however is that someone else also registers for DnD and
> disables the text editor's DnD support. If you try to write a
> MultiEditor you might want to look at
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=212244
I do not believe The bug is relevant because I have a main editor
"WorldEditor extends FormEditor" and, deep inside a page, I have a
"SceneEditor extends AbstractDecoratedTextEditor"; none of which has a
MultiEditor in its ancestry.
I put a series of breakponts and in the installed DropTargetAdapter and
I see calls to (in order):
dragStart()
isLocationSelected()
dragEnter()
dragOver()
.... and that's it.
I see no other calls; in particular I would expect to see at least
dragSetData() dragFinished() and drop()!
This is consitent with the fact the insertion pointer (thick vertical
bar) does not disappear.
I also tried setting breakpoints to
EditorSiteDragAndDropServiceImpl.realDropTarget.drop() but it is not called.
I also checked, but there's no call to removeMergedDropTarget().
EditorSiteDragAndDropServiceImpl.getCurrentDropTarget() is not called
after initialization either.
The only places where I have the word "drop" in my code is where I
implement D&D between two lists (actually from a List to a Table), but
that's another page and should not interfere (and works).
Any other idea about what I could have screwed so badly?
Mauro
> Dani
>> TiA
>> Mauro
Re: DragAndDrop in AbstractDecoratedTextEditor [message #553758 is a reply to message #545581] |
Wed, 18 August 2010 13:17   |
I am still struggling with this problem.
I have now a further data-point that could be meaningful for some
knowledgeable person:
I noticed that, for my editor, when
org.eclipse.ui.texteditor.AbstractTextEditor.initializeDragA ndDrop(ISourceViewer)
is called it fails:
Object object= Platform.getAdapterManager().loadAdapter(this,
"org.eclipse.ui.texteditor.ITextEditorDropTargetListener");
returns null.
This seems a good reason why Drag&Dtop it doesn't work, but I do not
know what I did to break it.
Probably I'm missing some required dependency, but I really don't know what.
Does this ring some bell somewhere?
Mauro
>>>>> Hi,
>>>>> initialization.
>>>>> true.
>>>>> anything usable.
>>>> Dani
>>>>> Thanks in Advance
>>>>> Mauro
>>> Thanks Daniel,
>> Inside
> dragStart()
> dragEnter()
> dragOver()
> ... and that's it.
> called.
> Thanks
> Mauro
>> Dani
>>> TiA
>>> Mauro
Re: DragAndDrop in AbstractDecoratedTextEditor [message #553831 is a reply to message #553758] |
Thu, 19 August 2010 02:30  |
> is called it fails:
> returns null.
Actually, it would be an indication of a bug if it wasn't 'null'.
> what.
The only thing I can say from the outside is that it looks like you try
to nest editors inside other ones and there some listeners seem not be
correctly installed and/or don't delegate the DnD events accordingly.
Dani
> Thanks
> Mauro
>>>>>> Hi,
>>>>>> required
>>>>>> initialization.
>>>>>> true.
>>>>>> anything usable.
>>>>> pages in
>>>>> Dani
>>>>>> Thanks in Advance
>>>>>> Mauro
>>>> Thanks Daniel,
>>> Inside
>> dragStart()
>> dragEnter()
>> dragOver()
>> ... and that's it.
>> called.
>> Thanks
>> Mauro
>>> Dani
>>>> TiA
>>>> Mauro
Current Time: Fri Jul 25 23:37:53 EDT 2025
Powered by FUDForum. Page generated in 0.06112 seconds
