Home » Archived » M2M (model-to-model transformation) » [ATL] Launch a transformation from a java application using metamodel by URI
[ATL] Launch a transformation from a java application using metamodel by URI [message #54404] Mon, 23 July 2007 07:08 Go to next message
Originally posted by: bch.openbluelab.org
I have read the question "How do I launch transformations
programmatically?" on the Wiki
( http://wiki.eclipse.org/index.php/ATL_Howtos#How_do_I_launch _transformations_programmatically.3F)
and I have used the java code writed by Dennis Wagelaar but I don't know
how to launch my metamodel by URI (in my example :
uri:http://www.eclipse.org/uml2/2.0.0/UML). Have you an idea ?
Best Regards
Benjamin CHEVALLEREAU
Re: [ATL] Launch a transformation from a java application using metamodel by URI [message #54540 is a reply to message #54404] Tue, 24 July 2007 05:15 Go to previous message
Benjamin CHEVALLEREAU schreef:
> Best Regards
The AtlEMFModelHandler.loadModel() method that I used takes a URI object
instead of a URI String. Only the URI String version of loadModel()
checks for the "uri:..." scheme. You'll need to change the code in
Main.loadModel().
Then make sure your Java program does all the EMF/UML initialisation
that is normally done by Eclipse. Check EMF/UML documentation on how to
do this.
Dennis
Previous Topic:[ATL] ant launch.xml problem with the AntPlugin
Next Topic:ATL User Manual
Current Time: Tue Oct 28 22:06:59 EDT 2025
Powered by FUDForum. Page generated in 0.21091 seconds
