Home » Eclipse Projects » Subversive » Problem with Flex Builder 3.2
icon8.gif  Problem with Flex Builder 3.2 [message #543851] Wed, 30 June 2010 15:08 Go to next message
I've now spent the good part of a day trying to get this working and I'm at a loss to what is going on.
I have an installation of Flex Builder 3.2 Stand alone. Is uses Eclipse version 3.3.1 It's been installed for ages using Subversive. I was having some trouble recently merging so I figured I would update my plugin and connectors to the latest version.
When I went to manage conifuration inside Flex Builder I noticed a ton of old disabled stuff related to SVN so I uninstalled it. I restarted and everything was nice and clean. Then I attempted to install 0.7.9 of the of the plugin with all the connectors available. When I restarted, I noticed that Flex Builder acted as if there were no SVN plugins at all. It was odd. THere was no SVN in the Team section of of the preferences.
At some point I started to give up so I copied the "features" and "plugins" folder from another machine where it's working. This has the 0.7.8 version. This kind of fixed it except the SVN connector tab show no connectors. When attempt to install connectors, it wants to install the 0.7.9 plug-in. When I do that, it goes back to not displaying anything again.
Can someone help me sort this out.
Mark
[Updated on: Wed, 30 June 2010 15:09] by Moderator
Re: Problem with Flex Builder 3.2 [message #544290 is a reply to message #543851] Fri, 02 July 2010 04:38 Go to previous messageGo to next message
Hello Mark,
Subversive 0.7.9 doesn't work on Eclipse 3.3 because of
org.eclipse.equinox.security dependency. If you have Subversive 0.7.8
you can try to install connectors from
http://community.polarion.com/projects/subversive/download/e clipse/2.0/galileo-site/
update site, I think they should be compatible.
> I've not spent the good part of a day trying to get this working and I'm
> anything again.
> Mark
Igor Burilo
Re: Problem with Flex Builder 3.2 [message #557317 is a reply to message #543851] Mon, 06 September 2010 12:22 Go to previous message
If you want to use other Eclipse plugins with Flex Builder, it's much better to install Eclipse, then Flex Builder as a plug in to it.
Previous Topic:problem with SVNKit 1.3.2?
Next Topic:Always get tree conflict on merge
Current Time: Wed Jul 23 08:17:08 EDT 2025
Powered by FUDForum. Page generated in 0.05250 seconds
