Home » Eclipse Projects » Subversive » Key bound to "SVN update" in Galileo works, does nothing in Helios
Key bound to "SVN update" in Galileo works, does nothing in Helios [message #543573] Tue, 29 June 2010 16:18 Go to next message
Before I file a ticket for this, I wanted to check if there is something that I'm missing.
In Galileo, I had a key (ctrl-alt-u) bound to "update" in the SVN category. If I have the focus in the Package Explorer in the project I want, or in the editor for a file in that project, pressing this key would do a SVN update, either on the project or the particular file.
I exported my preferences, including key bindings, and imported that to my Helios workspace. As far as I can see, everything still says that key is still bound to that function. I can even verify the binding with my Emacs+ plugin.
Unfortunately, even though it appears the binding is there, pressing the key does nothing. Nothing shows up in the error log.
Again, this works fine in Galileo, with the same set of key bindings.
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios [message #543690 is a reply to message #543573] Wed, 30 June 2010 06:21 Go to previous messageGo to next message
Hi!
I am experiencing the same problem. Noticed it in my setup so i tried to reproduce it from scratch:
unzip eclipse Helios RCP/RAP package.
install Subversive via Helios update site.
install svnkit for 1.6
checkout a project.
use default hot keys -> nothing.
Assigning other hot keys will not work either, selecting it via context menus works though.
Hope it's enough to reproduce the Problem.
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios [message #543760 is a reply to message #543690] Wed, 30 June 2010 09:43 Go to previous messageGo to next message
Am 30.06.2010 12:21, schrieb Pawl Crux:
> I am experiencing the same problem. [...]
This is a known problem, there is already an issue for it (well,
actually multiple ones) :-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309074
For subclipse (which suffers from the same problem), there is a
workaround: right-click on the perspective - "Custimoize ..." - "Command
Groups Availability" - add a checkbox to "Team". This has to be done
/for each perspective/ (where the keyboard-shortcuts are needed).
But I don't know if this works for subversive, too.
HTH,
Mark
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios [message #543767 is a reply to message #543760] Wed, 30 June 2010 10:04 Go to previous messageGo to next message
It does in fact help Smile
Thank you!
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios [message #543788 is a reply to message #543760] Wed, 30 June 2010 10:57 Go to previous messageGo to next message
Very helpful, but this actually didn't do anything. However, when I instead did the same thing for the "SVN" command group, that resolved all the issues I had with binding SVN commands to keys, in both Galileo and Helios.
This is for the Subversive plugin, just so that's clear.
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios-- SOLUTION [message #671074 is a reply to message #543788] Mon, 16 May 2011 13:22 Go to previous messageGo to next message
Here's that WORKAROUND, spelled out (for the rest of us):
To get your keyboard shortcuts working for Subclipse (or Team/CVS) in Helios 3.6, do the following:
Menu Window / Customize Perspective... / Command Groups Availability tab:
check the box for SVN (and Team).
You're done--- for the current perspective. Enter other perspectives and repeat, as desired.
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios-- SOLUTION [message #672001 is a reply to message #671074] Thu, 19 May 2011 09:56 Go to previous message
Originally posted by:
Thanks a lot, finally those Subversive shortcuts do work for me!
> Availability tab:
Previous Topic:Showing history with merged revisions fails using SVNKit
Next Topic:Merge question
Current Time: Sat Jul 26 23:22:43 EDT 2025
Powered by FUDForum. Page generated in 0.28432 seconds
