Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Import UML Profile to use in templates([Acceleo] Import UML Profile to use in templates)
[Acceleo] Import UML Profile to use in templates [message #542818] Sat, 26 June 2010 08:12 Go to next message
How can i import uml profiles for use in templates?
For example i have Persistence.profile.uml.
Do i need to register it somewhere?
What are the steps i need to do?
attila
Re: [Acceleo] Import UML Profile to use in templates [message #543743 is a reply to message #542818] Wed, 30 June 2010 08:54 Go to previous messageGo to next message
--------------040006060209090606030500
Hi Attila,
You cannot use profiles directly in Acceleo templates, you can however
use profiled UML models and access profile information through the usual
UML APIs.
For example if you have a class stereotyped "Entity" and you wish to
retrieve the value of its property ""; you can use :
[template public generateSomething(class : Class) ? (not
class.getAppliedStereotype(fqn::Entity).oclIsUndefined)]
class [class.name/] has stereotype fqn::Entity.
Its table_name tagged value is
[class.getValue(class.getAppliedStereotype(fqn::Entity), 'table_name')/]
[/template]
Does this suit your need? Otherwise please elaborate on what you need to do.
Laurent Goubet
Obeo
Bak Attila wrote:
> Thanks
> attila
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040006060209090606030500--
Re: [Acceleo] Import UML Profile to use in templates [message #543762 is a reply to message #543743] Wed, 30 June 2010 09:55 Go to previous message
This is exactly the info i was looking for!
Many thanks for your answer i will try it out!
regards,
attila
Previous Topic:[acceleo] Can we know the Generated List file of mainFile
Next Topic:[Xtend] Autocomplete / code completion problems
Current Time: Sat Jul 26 02:23:09 EDT 2025
Powered by FUDForum. Page generated in 0.03047 seconds
