Key bound to "SVN update" in Galileo works, does nothing in Helios [message #543573] |
Tue, 29 June 2010 16:18  |
Before I file a ticket for this, I wanted to check if there is something that I'm missing.
In Galileo, I had a key (ctrl-alt-u) bound to "update" in the SVN category. If I have the focus in the Package Explorer in the project I want, or in the editor for a file in that project, pressing this key would do a SVN update, either on the project or the particular file.
I exported my preferences, including key bindings, and imported that to my Helios workspace. As far as I can see, everything still says that key is still bound to that function. I can even verify the binding with my Emacs+ plugin.
Unfortunately, even though it appears the binding is there, pressing the key does nothing. Nothing shows up in the error log.
Again, this works fine in Galileo, with the same set of key bindings.
Re: Key bound to "SVN update" in Galileo works, does nothing in Helios-- SOLUTION [message #672001 is a reply to message #671074] |
Thu, 19 May 2011 09:56  |
Originally posted by:
Thanks a lot, finally those Subversive shortcuts do work for me!
George wrote:
> Here's that WORKAROUND, spelled out (for the rest of us):
> To get your keyboard shortcuts working for Subclipse (or
> Team/CVS) in Helios 3.6, do the following:
> Menu Window / Customize Perspective... / Command Groups
> Availability tab:
> check the box for SVN (and Team).
> You're done--- for the current perspective. Enter other
> perspectives and repeat, as desired.
FUDForum. Page generated in 0.03354 seconds
