Home » Language IDEs » ServerTools (WTP) » Dynamic Web Project setup with new Deployment Assembly page
Dynamic Web Project setup with new Deployment Assembly page [message #543209] Mon, 28 June 2010 13:11 Go to next message
So, like many, I seem to be having a bit of a problem working with the new Deployment Assembly page that has been added to the Dynamic Web Project Properties. Hopefully, you might be able to get me straightened out!
I have approximately 30 source folders that are in sub-directories all over the project that are added to the build path (such as "modules/core/src"). Most of these folders contain a java package hierarchy with source files, but a few simply contain a large number of configuration files (such as "modules/config/src"). Build and runtime libraries are scattered in a few different "lib" directories across the project as well.
Previously, in Galileo, setting up a new Dynamic Web Project was easy. Once all of the source folders and libraries were added to the build path, I simply had to go to the "Java EE Module Dependencies" preferences page and click "Select All". Publishing the project to a local Tomcat server after this worked like a charm.
In Helios, however, I seem to be having some issues getting Tomcat to see some of the configuration files once the project is published. In particular, I have a file called "default.loaders" that exists in the "modules/config/src" folder that one of my bootstrap servlets is having a hard time finding. The "modules/config/src" folder is a Java source folder and has been added to the "Deployment Assembly" page with its "Deploy Path" set to "/WEB-INF/classes". The "default.loaders" file exists in both the "modules/config/src" and "bin" folders, and yet my bootstrap servlet is still getting a FileNotFoundException when it attempts to open it.
Any ideas on what sort of configuration changes I might need to perform to make the files in my "modules/config/src" source folder visible to the webapp?
Re: Dynamic Web Project setup with new Deployment Assembly page [message #543213 is a reply to message #543209] Mon, 28 June 2010 13:34 Go to previous messageGo to next message
I should note, I just opened the Galileo workspace containing this project in Helios, and it suffers from the same issue. It looks like the Helios project configuration that resulted from the conversion of the Galileo project configuration is the same as the Helios project configuration I am creating from scratch, as detailed above. However, although the configuration works fine for running the application in Tomcat under Galileo, it does not for Helios.
Re: Dynamic Web Project setup with new Deployment Assembly page [message #543577 is a reply to message #543209] Tue, 29 June 2010 16:17 Go to previous messageGo to next message
> out!
> project as well.
> the webapp?
What you describe should work. Have you confirmed that the
"default.loaders" file is not found under
"<workspace> /.metadata/.plugins/org.eclipse.wst.server.core/tmp?/wtpweba pps/ <app_name>/WEB-INF/classes"?
If not, you might try experimenting in a separate project to see if some
aspect in your current project is confusing the publishing. Since it's
the output folder that gets published, I would think it would be
sufficient to have the Deployment Assembly page map just one source
folder that is tied to a particular output folder. I don't think
mapping multiple source folders which use the same output folder to be
necessary, though I don't think it should hurt.
If some cause can't be determined, a bug report would probably be in
order to investigate further. Since a non-working project will be
needed, you could try copying your project and removing as much as you
can to make it smaller while preserving its problem behavior, and attach
it to the bug.
Larry
Re: Dynamic Web Project setup with new Deployment Assembly page [message #543602 is a reply to message #543577] Tue, 29 June 2010 22:01 Go to previous messageGo to next message
Larry Isaacs wrote on Tue, 29 June 2010 16:17
it to the bug.
Larry
Thanks for the reply, Larry!
If I publish to Tomcat normally, everything does work, and the default.loaders file can be found there. The problem I described appears to only occur when serving modules without publishing, directly from the workspace. I also typically publish module contexts to separate XML files, so I diffed the working Galileo context XML with the nonworking Helios XML. The only difference is the addition of this attribute in the Resources element:
extraResourcePaths="/WEB-INF/classes|/Users/ioeth/Workspaces/ <workspace dir>/<project dir>/bin"
Not really sure what that attribute is used for, nor how it would treat the /WEB-INF/classes entry, since it looks like an absolute path. It also seems weird that the value in that attribute looks to be pipe-delimited, while the rest of the attributes in the module context file are semicolon-delimited.
I did some testing by editing the file manually, and can confirm that if I remove that attribute and value that my server starts up normally. Think it's time to enter a bug report?
Re: Dynamic Web Project setup with new Deployment Assembly page [message #543862 is a reply to message #543602] Wed, 30 June 2010 16:35 Go to previous messageGo to next message
>> "default.loaders" file is not found under "<workspace>
>> some aspect in your current project is confusing the publishing. Since
>> it's the output folder that gets published, I would think it would be
>> attach it to the bug.
>> Cheers,
>> Larry
> Resources element:
See if Bug 318449[1] applies to your use case. This would appear to be
a regression caused by the attempt to support multiple web content folders.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=318449
Re: Dynamic Web Project setup with new Deployment Assembly page [message #543888 is a reply to message #543862] Wed, 30 June 2010 19:16 Go to previous message
Larry Isaacs wrote on Wed, 30 June 2010 16:35
Larry
Thanks again for the quick response, Larry!
Yes, it appears that bug 318449 is describing the same problem that I am having. I may update that ticket with the information I've posted here as the cause of the issue might be that XML attribute I've identified previously.
Previous Topic:WTP Tomcat hot deploy with m2eclipse
Next Topic:Can't get XSLT debugger to use local DTDs (get HTTP 503 to w3.org)
Current Time: Wed Jul 23 04:25:02 EDT 2025
Powered by FUDForum. Page generated in 0.55210 seconds
