Home » Language IDEs » PHP Development Tools (PDT) » Xdebug stop working
Xdebug stop working [message #543551] Tue, 29 June 2010 14:15 Go to next message
hi, i have a problem that's driving me crazy.
i was using eclipse with xdebug and i could debug easily.
then i installed the new version of eclipse and....
puff!
i can't debug anymore.
i set up breakpoints and eclipse won't stop there.
what's happening?
thanks in advance, it's very important since i have a lot of work to do -.-
Re: Xdebug stop working [message #543674 is a reply to message #543551] Wed, 30 June 2010 05:02 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
Can you try with a clean workspace ?
Can you generate an xdebug log and post it along with your setup details
such as xdebug version, php version, operating system etc
to get a log see
http://www.eclipse.org/pdt/documents/XDebugGuideForPDT2.0.pd f
Dave Kelsey
> puff!
> what's happening?
Re: Xdebug stop working [message #543681 is a reply to message #543674] Wed, 30 June 2010 05:42 Go to previous messageGo to next message
ok, i applied a winfows-style solution: remove and re-install
now everything is fine.
O_o
Re: Xdebug stop working [message #544014 is a reply to message #543551] Thu, 01 July 2010 07:12 Go to previous messageGo to next message
ok, now i'm getting confused.
as i posted before, everything was ok.
now i get a "Waiting for XDebug session" warning...
i didn't touch anything!
what's happening?
EDIT: close + re-open and now it works... why these things are so random??
doing a netstat -a -b i get these info:
TCP LISTENING 3076
[eclipse.exe]
TCP LISTENING 3076
[eclipse.exe]
3076?? i set 10000 both in my php.ini and eclipse -.-
[Updated on: Thu, 01 July 2010 07:28] by Moderator
Re: Xdebug stop working [message #544036 is a reply to message #544014] Thu, 01 July 2010 08:18 Go to previous messageGo to next message
Read the document, get an xdebug log to help determine the problem.
Dave Kelsey
> what's happening?
Re: Xdebug stop working [message #544038 is a reply to message #544036] Thu, 01 July 2010 08:39 Go to previous message
ok, i'll do it asap
Previous Topic:Hide DEBUG SESSION ENDED
Next Topic:PDT on OSX 10.6 extremly slow
Current Time: Sun Jul 20 23:45:59 EDT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
