Home » Eclipse Projects » Remote Application Platform (RAP) » DateTime-Widget not reliable(What you see is NOT what you get. DateTime displays correct date, but "getDay" delivers wrong/old digit.)
DateTime-Widget not reliable [message #537428] Wed, 02 June 2010 08:34 Go to next message
Hi!
My DateTime-Widgets from RAP 1.3 RC2 act strange. I initialize them with the current date '2010-06-02'. Then I click into the spinner for months and type '01'. Then I click into the spinner for days and type '031' to get the 31th of january.
When I read the date from the wiget I get '2010-02-01'. It just "works" for the number 31, but any of the 31-months.
[Updated on: Mon, 12 July 2010 07:03] by Moderator
Re: DateTime - Bug? [message #537818 is a reply to message #537428] Thu, 03 June 2010 13:49 Go to previous messageGo to next message
I couldn't reproduce what you describe. You would expect 2010-01-31 as a
result, right?
However, you should file a bug if you think it is one. Please provide
further information if possible.
Rüdiger
On 02.06.2010 14:34, Bassspieler wrote:
> Hi!
icon4.gif  Re: DateTime - Bug? [message #543378 is a reply to message #537818] Tue, 29 June 2010 05:17 Go to previous messageGo to next message
Ok, now it's already an open Bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=315950
But I really do have to stress the importance of this, I guess.
(1)
DateTime-Widget initialized with "01.06.2010"
- Open drop-down-calendar
- Switch to May
- Select "31"
- Query the date from the DateTime-Widget
-> "01.05.2010" is your result (wrong)
But it get's even more strange.
(2a)
DateTime-Widget initialized with "01.05.2010"
- Switch to June
- Select "14"
- Query the date from DateTime-Widget
-> "14.06.2010" is your result
- Switch to may
- Select "31"
-> "14.05.2010" is your result (wrong)
(2b)
- Switch to June
- Select "14"
- Do not Query the date from DateTime-Widget
- Switch to may
- Select "31"
-> "31.05.2010" is your result (right)
If you can reproduce this, than it's an absolutely critical bug for any running application, isn't it?
Or am I just using the DateTime-Widget the wrong way?
Bassspieler
Here is the snippet, that I used:
import org.eclipse.jface.dialogs.TrayDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.DateTime; import org.eclipse.swt.widgets.Shell;
public class DateTimeDialog extends TrayDialog {
	private DateTime dtDate;
	public DateTimeDialog(Shell shell) {
		super(shell);
	protected Control createDialogArea(Composite parent) {
		dtDate = new DateTime(parent, SWT.DATE | SWT.DROP_DOWN | SWT.BORDER);
		dtDate.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, false, false));
		dtDate.setDate(2010, 5, 1); // this is: "2010-06-01"
		return parent;
	protected void okPressed() {
		System.out.println(dtDate.getYear()
			+ " " + (dtDate.getMonth() + 1) // to see the "human" month-digit
				+ " " + dtDate.getDay());
[Updated on: Tue, 29 June 2010 05:28] by Moderator
Re: DateTime - Bug? [message #543384 is a reply to message #543378] Tue, 29 June 2010 05:27 Go to previous messageGo to next message
Very Happy
Right the minute I did post my last message, some great guy posted the "fixed in CVS" in the bug-tracker. So, thanks to Ivan Furnadjiev.
Is there any way to integrate this into my application, asap?
Bassspieler
Re: DateTime - Bug? [message #543395 is a reply to message #543384] Tue, 29 June 2010 05:36 Go to previous messageGo to next message
only one class is affected by this fix - DateTimeDateLCA. Changes are in
readData method.
HTH,
Ivan
On 06/29/2010 12:27 PM, Bassspieler wrote:
> :d https://bugs.eclipse.org/bugs/show_bug.cgi?id=315950
> Best regards,
> Bassspieler
Re: DateTime-Widget not reliable [message #543404 is a reply to message #537428] Tue, 29 June 2010 06:45 Go to previous messageGo to next message
Sorry, I never did change my used RAP runtime target. But I guess, it's all about creating a patch fragment, isn't it?
http://wiki.eclipse.org/RAP/Patch_Fragments
Re: DateTime-Widget not reliable [message #543439 is a reply to message #543404] Tue, 29 June 2010 08:57 Go to previous message
Yes, you can try it... The second approach is to work against the CVS
HEAD (RAP source).
Best,
Ivan
Previous Topic:a custom widget that make ajax call to communicate with the rap server
Next Topic:gc.drawImage()
Current Time: Sun Jul 27 08:08:44 EDT 2025
Powered by FUDForum. Page generated in 0.04538 seconds
