Home » Archived » M2M (model-to-model transformation) » [QVTo] global variables for transformation(How to set, instantiate, etc. global variables to used as additional input parameter for a transformation)
[QVTo] global variables for transformation [message #539426] Thu, 10 June 2010 12:59 Go to next message
Hi @all:
I need to do a switch case in my transformation. Something like, if x:= true do ttransformation xyz else tranformation xyz'
due to the fact that in my case the differences between xyz and xyz' are pretty small I want to use an additional input parameter of boolean for my transformation.
I did not find a lot of information about global variables in QVTo at all. just the following:
transformation UmlCleaning(inout umlmodel:UML14)
extends MyUmlFacilities(UML14),
access MathUtils;
var allSuper : Set(Class); // a global variable
main () {
allSuper := umlmodel.objectsOfType(Class)->collect(i|i.getAllBaseClasses());
(taken from QVT Specification 2.0 chapter 8.1.3)
so I tried the following:
transformation Arsep2Tsp(in arsep : ARSEP, out tsp : TSP);
var complMode_ : Boolean;
main() {
	complMode_ := true;
this does not work anyway.
So does anybody know how to use global variables?
Or even better: how to use additional parameters for a transformation?
Thanks!
Chris
Re: [QVTo] global variables for transformation [message #539472 is a reply to message #539426] Thu, 10 June 2010 17:18 Go to previous messageGo to next message
Hi C. Kopf ,
Please, consider using configuration properties.
For example, declaring configuration property of boolean in
transformation like follows:
modeltype ECORE uses "http://www.eclipse.org/emf/2002/Ecore";
transformation Ecore2Ecore(in input : ECORE, out output : ECORE);
configuration property myFlag : Boolean;
main() {
// here we can use myFlag ..
if (myFlag) then {
} endif;
Configuration properties appear in separate "Configuration" tab in QVTo
launch configuration so might be assumed as addition parameters to
transformation.
Sergey.
C. Kopf wrote:
> Hi @all:
> my transformation.
> Quote:
>> access MathUtils;
>> main () {
>> allSuper :=
> main() { complMode_ := true;
> Thanks!
> Chris
Re: [QVTo] global variables for transformation [message #540219 is a reply to message #539426] Tue, 15 June 2010 08:35 Go to previous messageGo to next message
Thanks a lot Sergey,
I used a property as a work around, configuration property is just what I looked for. Thanks!
Re: [QVTo] global variables for transformation [message #543260 is a reply to message #539426] Mon, 28 June 2010 16:33 Go to previous message
Hi!
Is there a way to define a global variable that can access from all operations of a transformation? I've tried
var myRegistry : Dict(String, Integer);
after the transformation header. This doesn't work (syntax error). I've also tried
property myRegistry : Dict(String, Integer)
and it's doesn't work too (collection not implemented error). I don't know the difference between a variable and a property but a property was the only way to define something globally Smile
ciao
Olli
Previous Topic:how to access a tagged value of a stereotype??
Next Topic:How does ATl deal with many source models in the normal execution mode
Current Time: Mon Jul 21 11:51:16 EDT 2025
Powered by FUDForum. Page generated in 0.07864 seconds
